On each tooth, is it taking out the whole valley in one pass, or is it multiple passes goiing deeper on each? With the 12L14 discs, it may start accumulating heat, don't want the cutter getting hot and ruining the temper.
That will be a tricky one to do for sure and I have often wondered how they were made so well in the "olde" days. Fingers crossed for a good outcome Kim.
When you've mastered those teeth can you sort mine out please, my dentist always looks clueless when I open wide
