Author Topic: Elegent Scroll Frame Skeleton Clock  (Read 188332 times)
Offline Sanjay F
Re: Elegent Scroll Frame Skeleton Clock
« Reply #255 on: April 12, 2025, 12:20:21 am »
Wow, really impressed, especially having watched how methodical and careful you've been through each process
« Reply #256 on: April 12, 2025, 12:43:56 am »
Oooh, thats all pretty!  The washers have great detail, much better than just flat discs. That second picture makes it look like its silver plated.
 :popcorn: :popcorn: :popcorn:
  • Oregon
« Reply #257 on: April 12, 2025, 03:03:27 am »
I admire humility Kim, but you've been doing truly nice, craftsman level work. Just lovely. :ThumbsUp: :ThumbsUp: :cheers:
« Reply #258 on: April 12, 2025, 04:59:57 am »
Thank you Sanjay, Chris, and Ron!  :cheers:
« Reply #259 on: April 12, 2025, 08:19:07 am »
Beautiful work Kim  :ThumbsUp:
Per          :cheers:
« Reply #260 on: April 12, 2025, 11:30:39 am »
Hi Kim, it really looks very elegant. Now I realize how big the watch is.
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #261 on: April 12, 2025, 11:43:52 am »
That is coming along nicely Kim. That is a lot of work in anyones book and it would be easy to lose your place and get destracted. Supburb work so far.
 :cheers: :cheers:
Tom
« Reply #262 on: April 12, 2025, 03:48:28 pm »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: The frame assembly is looking great Kim!  :cheers:
« Reply #263 on: April 12, 2025, 05:57:25 pm »
Thanks Per, Michael, Tom, and Jeff!  :cheers:
« Reply #264 on: April 13, 2025, 12:54:22 pm »
Do you have any concerns with corrosion from dissimilar metals in contact?
« Reply #265 on: April 13, 2025, 04:38:17 pm »
Hmmm.... No.
But that may be due to my inexperience and a lack of knowledge. Should I be worried about that?  :thinking:
« Reply #266 on: April 13, 2025, 05:04:57 pm »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: If corrosion was a concern at all, you could reduce the likelihood of it just by assembling things with a coat of silicone grease in the joints, or dielectric grease. A good coat of paste type floor wax on the aluminum plates will help them stay bright too. Just food for thought on no-stress Sunday!  :Lol:
« Reply #267 on: April 13, 2025, 06:14:31 pm »
What other metals does aluminum react with? We are not usually  using things in salt water, but humidity is a factor?
« Reply #268 on: April 14, 2025, 10:53:00 pm »
Seems like stainless steel shouldn't be too creative with humidity, or even other metals.  The only other metals that I'll be using besides aluminum is some W-1 Steel for the bearings.
Hmm... interesting thoughts.  I'll have to keep my mind open on this front.
« Reply #269 on: April 14, 2025, 10:55:44 pm »
Over the weekend I completed the Top Pillar:
And today I completed the Bell Standard and the Finial.
Someday, there will be a bell between the top of the Bell Standard and the Finial.
I freehanded the Finial – a little lathe Etch-A-Sketch and a lot of filing.  I think it came out pretty nice!
There’s still the Back Cock and supporting pieces, which I consider part of the frame.  But I can’t shape the Back Cock till I can shape the inside of the upper part of the frame.  So I’m going to leave that till later.
So next up will be the barrel for the main spring.  That’ll be fun!
