General Category > Chatterbox
Cam Bam Stick Font
(1/1)
gldavison:
Cam Bam site is down so asking here.
I've added a pen holder to my cnc router . I wanted to print a series of numbers on a block of wood. Using cam bam stick font number 3. The file prints all the numbers in the correct places but, it goes over each digit twice before it moves over to the next digit. So the pen drops, makes the digit and then returns to the starting point without lifting up. So it' doing each digit twice.
Am I missing something in the MOP that is causing this??????
stevehuckss396:
I assume you are using the engraving mop. Check that the final depth and depth of cut is the same. If final is 4 and depth of cut is 2 cambam will make 2 passes.
Navigation
[0] Message Index
Go to full version
