Author Topic: DIY Homemade Rat Steam Engine No.2  (Read 5535 times)
Offline Jim
  • South Coast of New South Wales, Australia
    • Blue Heeler's Model & Toy Steam Engine Room
« on: October 12, 2024, 02:23:23 AM »
It’s the school holidays down here in Oz and we also had a recent Long Weekend (yes we’re the land of the Long Weekend here) and myself and my 13 y.o Grandson made RAT ENGINE #2. (RAT ENGINE #1 we made some time ago).I put out a call if anyone had some Mamod parts laying around and my friend Walter over Western Australia answered the call.
We had to make a new brass piston as the original was very worn. RAT ENGINE #2 is made out of 2” copper plumbers’ pipe and 2” copper end caps. One of the end caps we turned down in the lathe so that it sat on the burner part of 2” copper pipe and that was silver brazed on.
The Mamod engine bracket was copper riveted on and then silver brazed on the inside of the pipe over the copper rivet and a touch of silver braze on the outside.
The ˝” chimney stack we did something new, and silver brazed in some copper pipe cross sections (really made a difference to boil times).
Made up brass (yes only from brass) bushings for the safety valve and for the water level plug and tapped the safety valve bushing for a Jensen safety valve and the water level plug 6mm and turned up the water level plug out of some scrap brass. We had some fun lighting a fire under the boiler with some gumtree cut up branches and leaves mixed in with a fire starter to test the boiler for leaks with only the safety valve installed.
The chimney stack is silver brazed into the firebox and we did that on our brick hearth….the rest of boiler was soft soldered together. Also, silver brazed up the gas burner.
Turned the chimney cowl on the metal lathe from some scrap.
Brazed three (3) copper feet onto copper burner section of the boiler. Needed to turn up some brass risers under the feet for the gas burner to work better.
There are some brass risers under the 5mm steel plate to help keep the heat off the routed timber plinth.
Bent and soft soldered in the K&S copper piping and made a copper bucket (silver soldered) for the condensate and soft soldered on a small copper spike on the copper pipe for it to swing on.
Cut the 5mm mild steel plate on the bandsaw and drilled and tapped it for the brass bolts.
Pickled the boiler in a strong Citric Acid solution.
 All in all it was a GREAT time together, could it have been built better? Yes, but then my 13 y.o Grandson wouldn’t have had the fun and lessons of using all those tools and techniques. Instead of just watching, he was hands on building it.
We had some fun hours now the last couple of days steaming this together.
Kind regards,
Offline Jim
Re: DIY Homemade Rat Steam Engine No.2
« Reply #1 on: October 12, 2024, 02:25:48 AM »
Some more pics
Kind regards,
Offline Jim
« Reply #2 on: October 12, 2024, 02:26:38 AM »
A few more pics
Kind regards,
« Reply #3 on: October 12, 2024, 07:13:00 PM »
A cool project!
I really like the steam engine with boiler.
I think it will steam soon.
Offline Jim
« Reply #4 on: October 13, 2024, 01:26:26 AM »
A cool project!
Thank you Michael, very much appreciated.
Kind regards,
Offline Chipswitheverything
« Reply #5 on: October 13, 2024, 09:05:51 AM »
This has been a great little project to have involved your young grandson in, now that these sort of skills and interests are not common among young people in the way that they were long ago, it introduces him to something completely different.  And something that can be enjoyed across a couple of generations, and is a big change from looking at a screen.
 I hope it will make the young man think of enjoying more practical activities as he goes through life; things that one is introduced to and find fun at that formative age often are important later on, tend to direct one to good hobby and interest choices. Dave
Offline MJM460
« Reply #6 on: October 13, 2024, 09:30:03 AM »
Hi Jim, a great project to do together.  And well done to complete it in the time you had available.
Can I ask where you got the isolation valve and the nozzle for the butane gas canisters?
And what does Rat stand for or where does it come from.  Not a description I have heard before in that context.
Offline Jim
« Reply #7 on: October 13, 2024, 11:46:19 PM »
Thanks Dave, appreciate your sentiments entirely.
Kind regards,
Offline Jim
« Reply #8 on: October 13, 2024, 11:55:35 PM »
"Rat Steam Engine" is just a play on "Rat Rods" and "Rat Bikes" mechanical things made up from parts.....may not look the best but work perfectly.
Over the years here is where I have bought most of my gas related items for running my steam engines (which run on gas) now I just usually buy jets (because I can't make them) and make everything else I need -
https://www.forest-classics.co.uk/ceramic-burners
Kind regards,
Offline MJM460
« Reply #9 on: October 14, 2024, 10:19:28 AM »
Thanks, Jim.  Interesting website
Offline Jim
« Reply #10 on: October 18, 2024, 12:34:25 AM »
MSM in Melbourne have some gas gear for models as well, but I prefer the BIX brand.
Kind regards,
Offline MJM460
« Reply #11 on: October 18, 2024, 11:51:21 AM »
Thanks Jim, I actually have a boiler from them, so an obvious place to start.  Not too far to pick up direct, though that might cost more than postage.
