The Showcase > Vehicles & Models
Kim's A3 Pennsylvania Switcher
<< < (2/9) > >>
Admiral_dk:
What a Wonderful Lokomotive and Tender  :praise2:
The latest addition looks fantastic too with the color printed Face  :whoohoo:
Thank you so Much for taking Us All along for this Amazing build  :praise2:
Per      :cheers:
MJM460:
Well done on reaching the end of construction.  And I do hope the engine will continue to give you joy for years to come.
It’s been a great journey and you have beautifully recorded it, and I have been following from the beginning.  (I did not realise it had been quite so long though.  But I am sure to you at times it must have seemed longer.)
I am also one of the many who feel the pressure gauge was beyond me, but you have made it seem within reach (almost).  And I am so glad you made the dead weight tester, so you can check the gauge (and any others you come by) whenever you want.  I have added that at least to my build list.  Dealing with dodgy pressure gauges over many years and witnessing the calibrations for many years made me appreciate the value of that device.
Thank you for all the work you have put into documenting it all so we can follow along and enjoy the journey with you.
wagnmkr:
A wonderful accomplishment Kim. The journey has been worth it as you have a beautiful engine there.
 :cheers: :DrinkPint: :cheers:
Tom
Kim:
Thank you all for your kind words!  It has been a very enjoyable journey, made even more so by sharing it with you all. Thank you!
Kim:
--- Quote from: MJM460 on October 06, 2024, 11:13:56 AM ---I am also one of the many who feel the pressure gauge was beyond me, but you have made it seem within reach (almost).  And I am so glad you made the dead weight tester, so you can check the gauge (and any others you come by) whenever you want.  I have added that at least to my build list.  Dealing with dodgy pressure gauges over many years and witnessing the calibrations for many years made me appreciate the value of that device.
--- End quote ---
The pressure gauge was much less of a struggle than I had imagined.  I would encourage anyone to build it!  I found it very rewarding.  And seriously, if anyone is interested in doing so, I would gladly share some 0.005" phosphor bronze with you to help you out!  Just let me know.
As for the dead weight tester, that was a fun project also, and not too difficult, much simpler than the pressure gauge for sure.  However, I'm not sure how much value it would be as a general pressure gauge tester.  As i found, the amount of air it can displace is VERY small.  I doubled that with my longer plunger, but still, I'm not sure if it would work well with larger pressure gauges with more dead air space in them. The bourdon tube tester that I made from Kozo's plans had VERY little dead air space in the tester which is why, I believe, this little tester worked well with it.  So just that gentle warning about using it at a general dead weight tester.  It might work.  It's possible that other leaks that I had in the system were what caused me problems with my stock pressure gauge. Maybe I should go back and try it out with that gauge again now that I've seen it work!
Best of luck if you do try it MJM!  And please let me know if you'd be interested in any of the sheet phosphor bronze!
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
