Author Topic: What is it???  (Read 7755 times)
Offline stevendavis
What is it???
« on: September 26, 2024, 04:43:29 AM »
Can anyone tell me what this is??
If you want to see my super power, pull my finger!
Re: What is it???
« Reply #1 on: September 26, 2024, 06:59:38 AM »
Offline stevendavis
Re: What is it???
« Reply #2 on: September 26, 2024, 05:45:13 PM »
Thanks Jason,
Looks like it's used for maybe ribbon cable?? Or some type of other electrical connectors.
Offline pgp001
  • West Yorkshire - UK
Re: What is it???
« Reply #3 on: September 26, 2024, 07:49:57 PM »
I think that design would be called a "Toggle Press"
Offline uuu
Re: What is it???
« Reply #4 on: September 27, 2024, 08:23:29 AM »
The design suggests a limited travel with a high mechanical advantage - so some sort of riveting tool?
Wilf
Offline MMan
  • Hampshire, UK.
Re: What is it???
« Reply #5 on: September 27, 2024, 08:32:10 AM »
Hi All,
This is the press for fitting Insulation Displacement Connectors (IDC). IDC connectors terminate a large number of separate conductors all at once with no tedious striping of insulation. The cable is ribbon cable so the distance between conductors is well controlled, the connectors have a little piercing tooth on each pin and the action of the press is to push two parts of the connector together until they click at which point each conductor will be pierced and connected. Consequently the press travel is small but well know and so a high force over a small part of the travel is all that is needed (as this one delivers). There is specialized tooling per connector type that also sets the right distances, so little to set up. They were great when they first came inland I seem to remember them doing maybe up to 50 or 64 conductors at once.
All the best,
Martin
Re: What is it???
« Reply #6 on: September 27, 2024, 09:09:23 AM »
If there is one going then I can't see any reason it could not be put to use as a press for other things, it is really only the dies that make it suitable for connectors but it could be used for forming rivits etc. Stroke may not be enough if you want to drive a small keyway broach.
Offline stevendavis
Re: What is it???
« Reply #7 on: October 24, 2024, 05:45:39 PM »
Thanks for the replys,
I was also thinking of using it for a specialty press for small parts. I'd just have to make some form blanks.
