Author Topic: Chris's Ransome Tree Feller  (Read 10157 times)
« on: September 19, 2024, 01:56:55 PM »
The model of the Ransome Patent Tree Feller is complete. As noted in the buiild (well, both builds, first one was a bust), the valve system on this model was modified from the original Ransome design, which I was not able to get to run well. This new design of the valve uses a shuttle valve similar to the ones in some boiler feedwater pumps. Details on that and diagrams are over in the build thread in the Supporting/Vehicles And Models section of this forum. This design is working quite well, much happier with it!
Ready for some test cuts on a pine 'tree'...
<a href="https://www.youtube.com/watch?v=9j-FLzKmMqo" target="_blank">http://www.youtube.com/watch?v=9j-FLzKmMqo</a>
Running pretty well, took a few tests to get the pressure and valve setting to give it enough power to get through the 'tree', which is held by a screw through the end of the display base, with a threaded insert in the display base to take the screw. The saw itself is bolted up through the display base to hold it in place. Running pretty good!!  :cartwheel:
Here are some pictures too...
Offline tghs
Re: Chris's Ransome Tree Feller
« Reply #1 on: September 19, 2024, 02:04:17 PM »
just in time to start getting firewood for the winter,,  :cartwheel: :cheers:
what the @#&% over
« Reply #2 on: September 19, 2024, 05:35:08 PM »
That is ever so cool, Chris! Wonderful tree feller.   :ThumbsUp: :popcorn:
Well done!
« Reply #3 on: September 19, 2024, 05:43:34 PM »
Thanks guys!
If I start now, I could have enough firewood for a couple of winters from now...   :Lol:   If I had a fireplace, that is...  :shrug:    :Jester:
« Reply #4 on: September 19, 2024, 07:01:07 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: It runs great Chris! No more frustration with lack of reciprocation!  :Lol:  :facepalm: :facepalm2:
Liked the special "trunk clamp" ! I think you have just the right blade for it too.  Another great build.  :cheers:
« Reply #5 on: September 19, 2024, 07:10:20 PM »
Thanks Jeff! Its great to get this one running so well, the first attempt was pure frustration.
 :cheers: :cheers:
Online bent
« Reply #6 on: September 19, 2024, 09:57:54 PM »
Hooray!  Awesome work Chris!   :ThumbsUp: :cheers: :whoohoo:
That valve box does the trick perfectly.  Are you going to update the new and improved model name to ElfenLopper 2000?
  • Oregon
« Reply #7 on: September 20, 2024, 01:23:02 AM »
Another interesting and well executed project from you, Chris! Since you don't have a fireplace, maybe you could put to work as a salami slicer? You know, for nibbling along with a Steam Beer?
« Reply #8 on: September 20, 2024, 02:25:05 AM »
Thanks  guys!
Hmm, maybe make the first steam powered cheese slicer...   :Lol:   or use it to cut chunks off those big dark chocolate  bars!   :P
Offline Krypto
« Reply #9 on: September 20, 2024, 02:48:56 AM »
Wow, that model is working great!  I was surprised how easily and quickly it cut the demo board.
Would an old school (12") Gi-Joe action figure be about the appropriate scale size for the operator?  I've been looking at some of the wood-cuts of the Ransome and they show it smaller than I thought it would be.
« Reply #10 on: September 20, 2024, 01:09:28 PM »
They would probably about the right size. I didn't  build it to any particular  scale, just sized it for the lathe and bar stock on hand.
Offline Chipmaster
« Reply #11 on: September 20, 2024, 01:13:58 PM »
Impressive  :ThumbsUp:
Andy
Offline Charles Lamont
« Reply #12 on: September 20, 2024, 09:11:48 PM »
Nice feller, fella
« Reply #13 on: September 21, 2024, 10:05:51 AM »
Woodman spare that tree, touch not a single bough!
« Reply #14 on: September 22, 2024, 12:51:57 PM »
Another truly outstanding and unique build Chris! I'm glad you finished it. It makes me wonder how well the original saw worked with the twisted valve rod?
