Help! > Hints, Tips & Tricks
Adjustable sight oiler with drip reservoir.
<< < (2/2)
Bruno Mueller:
--- Quote from: Krypto on September 16, 2024, 03:40:27 am ---Nice work!  I probably should make an scratch-built oiler for my next, next project and your work provides inspiration.
--- End quote ---
#Krypto#
if you want to rebuild the oilers, I also have a drawing for it. the actual idea didn't come from me. I just changed the dimensions and modified the covers a little.
The last oiler with the constriction on the tank glass is slightly smaller . the outer diameter of the glass is 10 mm at the top and 7 mm at the bottom. The connecting tube has a diameter of 3 mm.
Krypto:
Thank you!
Navigation
[0] Message Index
[*] Previous page
Go to full version
