Author Topic: Mery Explosive Engine  (Read 78124 times)
Offline Chipmaster
Re: Mery Explosive Engine
« Reply #240 on: January 14, 2026, 03:51:48 PM »
Hi Graham, is this arrangement what you're suggesting?
IMG_2915 by Andy, on Flickr
Unfortunately it was too cold for me to stay in my garage this afternoon. I'll give it a go tomorrow when my gas heater has raised the temperature.
Andy
Offline Alyn Foundry
« Reply #241 on: January 14, 2026, 04:14:08 PM »
Yes, that’s perfect.   :ThumbsUp:
You should be able to finely control the mixture via the control knob. I’d suggest using the motor to drive the engine whilst performing the adjustments.
 :cheers:  Graham.
Offline Chipmaster
« Reply #242 on: January 16, 2026, 05:06:21 PM »
My Mery Explosive ran for the first time this afternoon after revising the gas supply and retarding the ignition.
<a href="https://www.youtube.com/watch?v=U449tYGyxF8" target="_blank">http://www.youtube.com/watch?v=U449tYGyxF8</a>
It was running too fast and soon loosened the clamps holding it down so I had to stop it. The smoky exhaust is due to the cylinder lubrication oil that has accumulated over a period of attempts to get it running.
I think retarding the ignition still further will stop the knocking which sounded like pinking. Setting up a cooling system and a fair amount of fine tuning will follow.
Andy
« Reply #243 on: January 16, 2026, 05:25:44 PM »
 :whoohoo:
Offline Chipmaster
« Reply #244 on: January 16, 2026, 05:55:20 PM »
Hi Jo,
I was very surprised when it suddenly started after so many failed attempts  :cheers: :cheers: :cheers: :ThumbsUp:
Andy
« Reply #245 on: January 16, 2026, 06:45:04 PM »
Congratulations Andy…. :ThumbsUp:
Another thoroughbred to add to your ever growing Stable.
 :cheers:  Graham.
« Reply #246 on: January 16, 2026, 06:57:45 PM »
Congrats!
« Reply #247 on: January 16, 2026, 07:49:03 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: she's a runner!  :cheers:
Online Sanjay F
« Reply #248 on: January 16, 2026, 10:36:58 PM »
Brilliant, well done, looks great, what a fabulous achievement :ThumbsUp: :ThumbsUp:
Offline Chipmaster
« Reply #249 on: January 17, 2026, 10:26:31 AM »
Thanks chaps, to be continued….
Andy
Online Roger B
« Reply #250 on: February 01, 2026, 06:43:13 AM »
Congratulations on the first run  :praise2:  :praise2:  :wine1:
Looks and sounds great  :ThumbsUp:
Offline propforward
  • MN, USA
    • Stuart's Shednanigans
« Reply #251 on: February 01, 2026, 02:06:09 PM »
Lovely engine - I know from speaking to a few builders of this engine, including Gary Martin, that these are very sensitive engines and not an easy accomplishment, so very well done indeed.
Stuart - "He Meant Well"
Online Twizseven
« Reply #252 on: February 01, 2026, 05:50:54 PM »
Well done Andy. A complicated engine well executed.
 :DrinkPint:
Colin
Offline Chipmaster
« Reply #253 on: February 03, 2026, 12:22:32 PM »
Thanks for the comments Roger, Colin and Stuart - sensitive engine yes indeed it is. I haven't been able to get it to run since those videos posted on YouTube. I have tested the output from my propane regulator with a manometer and found it's really erratic at it's lowest settings. Searching around the internet it seems regulators with low pressure outputs such as 2" water column / 0.07 pounds per square inch or 5 millibar are very expensive.
So, I'll set the regulator at it's lowest consistent setting (1/2 psi) and rely on the needle valve in the engine's mixer to get the mixture right.
Naturally any suggestions gratefully received  :ThumbsUp:
Andy
Offline MJM460
« Reply #254 on: February 03, 2026, 10:19:42 PM »
Hi Andy, well done on getting the engine running.  I am sure you will sort out the fuel issue.
I am not sure what your fuel set up includes, but have you tried reducing the propane fuel pressure in two stages.
If you have a regulator set at something around 3 to 7 psi, 0.3 to 0.5 bar, the second regulator with the lower inlet pressure will have to open further and will usually be more reliable that way.
Reducing the full propane pressure to the required engine inlet pressure in one step requires the regulator to operate very nearly closed, and even very expensive large diaphragm industrial regulators work better in two stages.
I hope that helps.
