Author Topic: Microcosm J065 Worlds Smallest HoneyBee Stirling Engine  (Read 6790 times)
Offline Jim
  • South Coast of New South Wales, Australia
    • Blue Heeler's Model & Toy Steam Engine Room
« on: September 05, 2024, 07:09:40 AM »
Has anyone ever made a small engine? Do you have a link to the build thread or photos of it?
<a href="https://www.youtube.com/watch?v=TmvHabivbTg" target="_blank">http://www.youtube.com/watch?v=TmvHabivbTg</a>
Kind regards,
Re: Microcosm J065 Worlds Smallest HoneyBee Stirling Engine
« Reply #1 on: September 05, 2024, 07:49:31 AM »
Try this for size
<a href="https://www.youtube.com/watch?v=YCjwlSX-tsY" target="_blank">http://www.youtube.com/watch?v=YCjwlSX-tsY</a>
Offline Jim
« Reply #2 on: September 05, 2024, 08:00:06 AM »
 Jason that is incredible and a credit to the skills of the maker.
I have a little run out (tiny but its there) on my Sieg C6 lathe. How accurate does a lathe have to be to make a Stirling engine?
My lathe is mounted on an old kitchen bench in my shed, I need to put it on a more substantial base (we flooded two years ago) and get the twist out of the bed.
Kind regards,
« Reply #3 on: September 05, 2024, 09:23:34 AM »
You could probably say the same about my Warco 280 but my stirling engines work OK. It does become more of an issue as the parts become smaller if you think of the runout in relation to the diameter then fairly easy to see that 10microns on my 40mm cylinder is not going to be that noticable but it is 10times greater on a 4mm piston and 40times greater if that piston is on a 1mm dia rod.
Runout can be compensated for by doing as much in one setting as possible, using collets or custom turned split bushes which should be better than the average collet’s runout. It is clearances and alignment of parts as much as concentricity, lapping the power piston is going to be the critical fit if you are making alpha or gamma types. it gets a bit more complicated on the beta types where the power piston and displacer are on the same axis so displacer rod needs to pass through the power piston but they have been Ok for the ones I have done.
I’ve not really looked to see what small barstock designs might be out there as I prefer a scale look but there should be something and it can always be scaled down.
Offline 90LX_Notch
    • YouTube Channel
« Reply #4 on: September 05, 2024, 09:59:04 AM »
This is the smallest engine that I’ve done.
Bore:  .046  (1.16)
Stroke:  .046  (1.16)
Column height: .312  (7.94)
Ports: .013  (.33)
Center Distance of ports .023  (.58)
Crank Pin .016  (.41)
Fly Wheel Dia. .156  (3.96)
<a href="https://www.youtube.com/watch?v=nJau0iNTYOg" target="_blank">http://www.youtube.com/watch?v=nJau0iNTYOg</a>
Proud Member of MEM
My Engine Videos on YouTube-
Online Vixen
« Reply #5 on: September 05, 2024, 10:43:57 AM »
Top notch.... tinyest Tiny ever?
« Reply #6 on: September 05, 2024, 11:19:38 AM »
Amazing work Bob.
Now it just needs a miniature boiler and boat to suit!
« Reply #7 on: September 05, 2024, 12:54:11 PM »
Wow! That's  incredible!
Offline Jim
« Reply #8 on: September 06, 2024, 01:05:01 AM »
Thanks for that post Jason, I’ve gotten hold recently of some books on building Stirling engines as my enthusiasm to build something from scratch has built up (instead of just modifying, repairing and ‘building on’ already built engines.
Again, appreciate your post.
Kind regards,
Offline Jim
« Reply #9 on: September 06, 2024, 01:06:22 AM »
Bore:  .046  (1.16)
Stroke:  .046  (1.16)
Ports: .013  (.33)
Just amazing that build!
I had to share -
https://www.officeofsteamforum.com/general-discussion/'ultra-tiny'-steam-engine/msg65332/#msg65332
Kind regards,
Offline 90LX_Notch
    • YouTube Channel
« Reply #10 on: September 07, 2024, 02:28:06 AM »
Thank you gentlemen for the nice comments.
Mike, it probably is the tinyest Tiny ever.
Jim, thanks for posting it on another site.
-Bob
Proud Member of MEM
« Reply #11 on: September 07, 2024, 02:44:23 AM »
So, next project is an ultra-tiny double-acting engine?
The pic that really made the teensy size hit home for me was the engine lost next to the M&M. Simply stunning.
 :praise2:    :NotWorthy:
Offline Jim
« Reply #12 on: September 07, 2024, 03:06:43 AM »
-Bob
G'day Bob,
Looking through your channel, this engine looks like a good candidate for my 13 yo Grandson and myself to build together -
<a href="https://www.youtube.com/watch?v=wSRwQtJ5OpI" target="_blank">http://www.youtube.com/watch?v=wSRwQtJ5OpI</a>
Kind regards,
Offline 90LX_Notch
    • YouTube Channel
« Reply #13 on: September 07, 2024, 09:15:17 PM »
Jim-
That engine was designed by NickG.  The plans were free on the HMEM site 15 years ago.  I left that site when it was sold.  I don’t know if the plans are still available.
-Bob
Proud Member of MEM
Offline Jim
« Reply #14 on: September 08, 2024, 11:50:45 PM »
Jim-
-Bob
Thanks Bob appreciated mate.
Kind regards,
