Author Topic: Borderer Cast iron scratch build  (Read 2999 times)
Offline Team ricky
« on: September 03, 2024, 01:03:12 PM »
Hi Chaps,
The beginning of a new engine built from stock no casting
Of the Borderer design with 5/8 bore 5/8 stroke majority built from cast iron
Reversing gear too!
Pictures of parts as I make them !
Edit Jo: Please post the bits of your engine as you make them not only the copyrighted drawing.
« Last Edit: September 03, 2024, 02:24:26 PM by Jo »
Offline Team ricky
Re: Borderer Cast iron scratch build
« Reply #1 on: September 03, 2024, 01:05:26 PM »
Plans
Edit Jo: Full drawing sheet removed due to copyright infringement.
« Last Edit: September 03, 2024, 02:19:52 PM by Jo »
Offline Team ricky
« Reply #2 on: September 10, 2024, 08:18:29 PM »
No problem Jo,
Here’s the crankshaft sorted ;)
Gone for more traditional counter weights, Nice and true and spot on dimensions
« Reply #3 on: September 11, 2024, 02:45:15 PM »
That's a nicely executed crankshaft. Well done! :ThumbsUp: :popcorn:
Offline Team ricky
« Reply #4 on: September 11, 2024, 06:26:17 PM »
Cheers!
Here’s the cylinder blank in cast iron
A fair bit of machining to do on this stock !
Offline Team ricky
« Reply #5 on: September 12, 2024, 11:29:30 PM »
One side’s channel machined ;)
Offline Team ricky
« Reply #6 on: September 13, 2024, 07:57:42 PM »
Here’s the cylinder blank ready to bore :)
I’ve got to wait on drills and reamers to do the next step!
Offline Team ricky
« Reply #7 on: September 16, 2024, 10:34:39 PM »
Here’s the bed plate in Cast iron, Just in checking the crankshaft clearance I have noticed the same too close tolerance between the crank webs and the inside of the bed, not a big problem to create clearance but what I’ll do is lay the crankshaft tight so to speak and then only relieve what’s needed, maybe 0.5mm per d end would work ;)
I’m not going to raise the crankshaft line as I had previously done on the Gun metal Borderer I’m nearly finished on …..
Offline Team ricky
« Reply #8 on: September 20, 2024, 12:47:59 PM »
Here’s the crankshaft being laid … All went well just a little adjustment on the middle bearing block height wise to get a smooth running shaft :)
Hopefully the drills and reamers arrive soon to make the bores
Offline Team ricky
« Reply #9 on: September 20, 2024, 11:22:11 PM »
Here’s a little more done ✅
One con rod / big end made and fitted
I went with bright mild steel no plating, I think this engine will be a shelf Queen not fitted to a boat so I figured keeping everything oiled will be fine and look authentic,
There are a few bits to make from bronze which I’ll do soon after the cylinder block is done
« Reply #10 on: September 21, 2024, 09:36:05 AM »
You continue to make good progress Ricky  :ThumbsUp:
I know it's an early question - but what kind of finish do you have in mind - painted or ?
Per    :cheers:
Offline Team ricky
« Reply #11 on: September 21, 2024, 01:08:37 PM »
Hi Cheers ;)
Yes it’s coming on well !
I think for this one a natural finish on the steel parts , I may nickel plate the brass/bronze then have a black lagging cover across the cylinders…. Probably no paint bar the red ring on the flywheel
Offline Team ricky
« Reply #12 on: September 22, 2024, 12:02:56 AM »
Here’s the bottom end pretty much done ✅
I made 3 silver steel oil cups , rod and bearing and the collums
Temptation was there to take a picture with the cylinder perched on top !!
Offline Minh Thanh
« Reply #13 on: September 22, 2024, 04:21:00 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp:
Offline Team ricky
« Reply #14 on: September 22, 2024, 05:34:48 PM »
Not put a lot of time in today but here’s the flywheel sized up true and ready to paint ;)
It was a Stuart models one so a little smaller but should pass !
