Author Topic: Large Skeleton Clock  (Read 16457 times)
Offline wagnmkr
  • Lindsay, Ontario, Canada
« on: August 28, 2024, 02:19:38 PM »
It has been a while since I posted anything here so here goes....
I find a box in the basement a couple of days ago and had no idea what was in it. Imagine my surprise when I found the bits and pieces of a printed clock. Once I saw what it was I remembered printing it  but I have no idea why I put it away without assembly.
Anyway there were only 2 parts that I hadn't printed so I got those going and put the thing together. The first run was not successful so I took it apart, did a couple of tests, and found that the bearings hadn't been degreased as good as they could be. An overnight soak in some degreaser, assembly again this morning, and when I hung it on the wall, away it went.
This was made from odds and sods of filament so it is quite multi coloured. I might do this one again, only in a better colour scheme.
<a href="https://www.youtube.com/watch?v=ZT84kPoE9vo" target="_blank">http://www.youtube.com/watch?v=ZT84kPoE9vo</a>
« Last Edit: August 28, 2024, 02:24:31 PM by wagnmkr »
Re: Large Skeleton Clock
« Reply #1 on: August 28, 2024, 04:04:22 PM »
That's a very nice clock!  I may have to make me one of those someday...  :ThumbsUp: :popcorn:
Offline wagnmkr
« Reply #2 on: August 28, 2024, 04:12:06 PM »
Hi Kim,
Yes, you will soon have time on your hands!
I'll go to my room now :cheers:
« Reply #3 on: August 28, 2024, 05:42:06 PM »
Hi Kim,
Take CNR6400 with you when you go.  Have someone lock the door from the outside.
Either we are alone in the universe, or we are not. Both possibilities are equally frightening.
Offline paul gough
  • Paul Gough
« Reply #4 on: August 28, 2024, 09:26:43 PM »
What a delightful re-discovery from the basement. Looks a very attractive piece of mechanical animation for a blank spot of wall. Regards, Paul Gough.
Offline wagnmkr
« Reply #5 on: August 28, 2024, 11:15:15 PM »
Thanks Paul. It is interesting to watch this clock work as it is all open. It can be a bit hypnotic after a bit.
I still cant remember why I didn't assemble or try to run this one, but with only having to print a couple of parts, it si the best running one yet I think. I am encouraged to do another in more consistant colours this time.
Cheers    :cheers:
Tom
Offline paul gough
  • Paul Gough
« Reply #6 on: August 29, 2024, 10:26:26 AM »
Hello Tom, Clocks of this type and tower clocks have always been a very tempting proposition for me but have never had the opportunity to get into horology. Too many other things encroach on time etc. I am with you in that they are enchanting and mesmerizing aparatus with considerable aesthetic appeal. I have seen some lovely wooden examples too. Good luck to you in developing more designs.  Regards, Paul Gough.
Offline wagnmkr
« Reply #7 on: August 29, 2024, 11:00:12 AM »
Morning Paul.
I must explain that I am not the designer of these clocks. I simply purchase the plans and go from there. It is all done by a gentleman that is much smarter...
https://www.stevesclocks.com/
Offline paul gough
  • Paul Gough
« Reply #8 on: August 29, 2024, 11:26:57 AM »
No shame in being a constuctor and enthusiast, most models of any sort are from existing plans and provide endless pleasure during and after construction. I am tempted to join with you and get a set of plans! Thanks for the web address. Regards, Paul Gough
Offline wagnmkr
« Reply #9 on: October 17, 2024, 11:10:17 AM »
Just a quick note to say that this clock is still going very well. It is crazy accurate and only needs a few seconds adjustment every couple of weeks. It is amazing when you consider it is mostly plastic. I wind it every seven days.
My next project will be a pendulum table clock that is weight powered but it will be self winding! There have been some mixed reviews about this one but it has been made to work.
Film at 11!
Tom
Offline wagnmkr
« Reply #10 on: October 17, 2024, 10:38:18 PM »
This is the motor/gear assembly that will be the power behind the rewind mechanism ... 1000 to 1 gear ratio.
Offline wagnmkr
« Reply #11 on: October 17, 2024, 10:40:26 PM »
This is the motor and battery case ...
It is a very tidy installation.
Tom
« Reply #12 on: October 18, 2024, 12:53:12 AM »
Fascinating project!   :popcorn: :popcorn:
Offline wagnmkr
« Reply #13 on: October 18, 2024, 10:35:54 AM »
Thanks Kim. Yes, it is an interesting concept for sure.
Tom
Offline wagnmkr
« Reply #14 on: April 25, 2025, 11:20:55 AM »
It's been a while but I just wanted to say that the Large Skeleton Clock has now been running for just over a year.
There are no signs of wear and it has a very satisfying sound as it ticks away. I wind it every 6 or 7 days.
All in all it was a satisfying project.
 :cheers: :cheers:
