Help! > Mistakes, muckups, and dangerous behaviour
Small broken taps blind hole fix easy
Jo:
It is always good practise to use a nice sharp tap when cutting bronze castings. Bronze grabs drills and snaps old taps :toilet_claw:
To an extent that it is worth using a fractional bigger tapping hole in bronze as well as plenty of lubricant.
crueby:
For bronze bar stock, I much prefer working with the Bearing Bronze alloys, the Silicon Bronze is really sticky stuff as Jo mentioned. For castings, not much choice!
mcostello:
There are at least 4 different kinds of alum. Make sure You get the right kind.
I left an aluminum part on the wood stove for a couple of days till i found it out.
Admiral_dk:
--- Quote ---There are at least 4 different kinds of alum. Make sure You get the right kind.
--- End quote ---
Do you happen to know the Chemical Formula for the correct/good one - it would help other tremendously in locating the right stuff ;)
Per :cheers:
uuu:
Here's a Wiki article on the stuff: https://en.wikipedia.org/wiki/Potassium_alum
Wilf
Edit: and an article on all alums, including the wrong ones: https://en.wikipedia.org/wiki/Alum
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
