Author Topic: Warning: system battery is low.  (Read 3171 times)
Re: Warning: system battery is low.
« Reply #15 on: July 03, 2024, 09:32:25 AM »
Mike - the SATA setting is VERY IMPORTANT !!!!!
You CAN NOT change this without re-Installing Windows !!!!
So though it is a bit of a shame that it wasn't installed with it set to ACHI (faster) - you will have to set it to ATA again - BEFORE you try to Boot (this isn't always critical - but better safe than sorry).
If you get this setting wrong the PC will try to access the HardDisk in a completely wrong way (sectors etc.) -> wrong addresses for the Data.
Having the Clock wrong might prevent you from Login if it is on a network ....
Best wishes
Per          :cheers:
Online Vixen
« Reply #16 on: July 03, 2024, 10:14:55 AM »
Thank you all for your help and contributions,
Internal fire.    Thank you, I have amended my previous post accordingly.
Krypto.     Thanks, yes I regularly back-up the important files to external storage.
Per. Thank you also. I feel I now better understand the difference between the ACHI and ATA settings. I read somewhere that Win XP ran under ATA and all later versions run under ACHI. However, it is sometimes difficult to tell if the information you find on the net is the truth or someones guesswork.
Best wishes
Per          :cheers:
I will certainly make sure it is set to ATA before I try to Boot, Wish I had known that before I threw the previous PC out.  :killcomputer:
Cheers   :cheers:
« Reply #17 on: July 03, 2024, 12:10:58 PM »
Yes and No : XP needs extra drivers on the installation Media (CD/DVD) before it is possible to use ACHI on XP .... and it is IMPORTANT that they are integrated with the Installation files before the CD/DVD is Created ...!!!
Have tried to 'Fix Dead PC's ' more times than I care to admit (because I got this setting wrong) - even when working as IT Supporter  :hammerbash:
This happened often enough that if one off us had a problem with an XP PC not booting - one of the others would automaticly ask 'Have you checked that the SATA Setting is correct (we had our XP PC's set to ACHI @ the University).
« Reply #18 on: July 03, 2024, 06:27:54 PM »
As not to tarnish Achims thread too much - I will comment on Windows versions here Mike  ;)
Anything pre Windows 95 third revision - forget about them ....
I liked Windows 95 & 98 - Loved XP  :Love:
Next really good version was Windows 7 - though I had to learn where some of the great things from XP where hidden (in the beginning).
Windows 8 = Trash - though the Phone version was not too bad ....
Took me quite a while to switch to Windows 10 - my most important CAD/CAM (electronics) didn't play well there (old version - took quite some time to get an upgrade). After a much newer CAD/CAM revision - I switched and are quite happy with Windows 10.
I hate Windows 11 - bad user interface  :killcomputer:  :cussing:   :wallbang:
Give me headackes everytime I have to help my father with his PC (run Win11) - why degrade the function + hide some of those any Tech needs the most + Worse - completely remove some of those too  :Mad:
Strange as a big part of Windows 10 is inside Windows 11 .... then again what did they think when they made Windows Millenium, 8 + more ....
Per    :cheers:
« Reply #19 on: July 03, 2024, 07:40:51 PM »
Just a thought: earth yourself before touching the motherboard  ;)
Online Vixen
« Reply #20 on: July 03, 2024, 07:59:10 PM »
Thanks Jo,
I remember that anti static stuff from when someone paid me.
Offline Laurentic
« Reply #21 on: July 03, 2024, 10:35:39 PM »
Good luck with the battery change Mike, but remember the old saying I hold firm, NEVER trust anything with wires coming out of it. It will always bite you.
Chris   :old:
Online Vixen
« Reply #22 on: July 03, 2024, 10:58:25 PM »
Ha ha
There are lot's of other things out there which bite
« Last Edit: July 03, 2024, 11:10:46 PM by Vixen »
