Author Topic: Hello from Brazil!  (Read 1001 times)
Offline sdougm
Hello from Brazil!
« on: June 05, 2024, 10:40:37 PM »
HI!
My name is Sidney and I live in Brazil, I am retired from the 3D video production industry and have always been a lover of machining and had it as a hobby along with model airplanes and old motorcycles, today I have a small workshop with a manual lathe, drill press column and an adapted CNC milling machine.
At the moment I have in mind to build a V-Twin engine to power a bicycle in the style of the first Harleys and Indians.
Offline pirmin
Re: Hello from Brazil!
« Reply #1 on: June 05, 2024, 11:17:24 PM »
 :cheers:Welcome on Board Sid !
Feel free to show us your Shop !
« Reply #2 on: June 06, 2024, 12:27:39 AM »
Hello there, and welcome!
If you are interested, I have drawings for a V-twin based on the early Curtiss motorcycle engines posted in the Plans and Drawings section. I guess it would have to be scaled up a bit to power a full size bicycle though.
https://www.modelenginemaker.com/index.php/topic,10950.0.html
Online Vixen
« Reply #3 on: June 06, 2024, 01:10:05 AM »
Hello Sidney and welcome to the MEM forum  :hi: :hi:
Tell us more about your ideas to build a V-Twin engine to power a bicycle. What size of engine are you thinking about? Is it intended just for show or are you wanting it to travel on the main roads?
« Reply #4 on: June 06, 2024, 05:24:52 PM »
Hi Sidney,
Welcome to the forum!
Offline sdougm
« Reply #5 on: June 06, 2024, 09:44:50 PM »
Hi Mike!
I think around 250 - 300cc for use it in the roads...
I ever want use my "toys"  ;)
Online Vixen
« Reply #6 on: June 06, 2024, 11:35:58 PM »
Hi Mike!
Hello Sidney
250 - 300cc for use it in the roads would be a like a full size motorbike. Perhaps it would be better to base your design on a full size motorbike engine, gearbox and clutch instead of one of our simplified miniature model engines. Sorry, I cannot tell you where to look for the design details.
Boa sorte com sua busca
Offline sdougm
« Reply #7 on: June 07, 2024, 12:07:21 PM »
Hi Mike!
Hello Sidney
Mike!
Full size complete engine plans is almost impossible find and a bit complex.
I want to try one V-Twin model and increase the size, i see some bigger Hoglet and appear very good.
I am searching for 45 degress model with enclosed cranckshaft and rockers and an oil pump
Online Vixen
« Reply #8 on: June 07, 2024, 01:41:22 PM »
Mike!
Have you discovered these plans from draw-tech    https://www.homemodelenginemachinist.com/threads/draw-tech.29067/
There are also two good build threads
https://www.homemodelenginemachinist.com/threads/another-knucklehead-built-via-castings-as-a-draw-tech-design-upscaled.36071/
https://www.homemodelenginemachinist.com/threads/another-knucklehead-build.27584/
Hope these may help you
Offline sdougm
« Reply #9 on: June 07, 2024, 06:38:55 PM »
Mike!
Thank you Mike! ;)
Online Vixen
« Reply #10 on: June 07, 2024, 06:46:09 PM »
Mike!
Thank you Mike! ;)
If you make all the parts twice as big (X2) as shown, you get a displacement of 290cc
Now all you need is a clutch and gearbox to match
