Hello Graham. Never heard of"Plumbers Black". Perhaps over here on the other side of the pond it has another name? Bob
It seems to me the press fit is an intermediary step to getting all the elements together in a stiff & aligned assembly, but what is doing the actual torsional resistance is the axial pin along the joint line. Maybe shrink fit + pin are somewhat additive but put it this way, if the joint ever did slip for whatever reason, it would boil down to the shear strength of the pin cross section area, no?
I was looking into taper pins & matching drills. Where do you guys source them? The pins were relatively inexpensive on McMaster Carr USA but OMG the drills are not cheap. I then lurked on AliExpress, lots of (seemingly standardized) 1:50 pins, but no drills unless they call them something different & I have yet to guess the password. But lots of matching reamers.
A multicylinder drone engine has crankshaft with 25mm dia parts pressed into 24.9mm holes with grip length of 17mm and test minimum torque is 600 Nm.He who proposes conical pins or loctite will be asked to leave..
The torsion on the joints is small. The engine block and bearings will take most of that at the crank pins. It's just the final drive that is a concern
