Engines > From Kits/Castings
Borderer Piston valve version
<< < (14/15) > >>
Team ricky:
Thanks for the heads up ;)
Here’s a little more complete!
Two pistons and one rod, pretty standard stuff but took care to get a close fit and a good ring groove !
I went with Vitron o rings mainly due to having good wear properties and heat resistance is good too , I’ll make the second rod and lower cylinder cover glands - after that lot I’ve pretty much got an engine
One problem I have caught is I had made the lower features of the cross head upside down after I had drilled the fixing hole (M3)
So to re- establish that hole on the other side concentric I have ordered the correct ER20 collet , If that fails I’ll make a new one , hopefully won’t need to tho and learning rescue methods is a good thing ;)
Team ricky:
Starting to feel like an engine now ;) I have finished the cross heads and pins and installed the rods and trunks to test!
All spinning over very well indeed
Team ricky:
Side on
Team ricky:
I made the flywheel and tidied the piston valve housings ;)
Also made and fitted the cylinder trunk gaskets and final fit for those too, A little blue locktite on the screws and span everything over and alls good !
The flywheel is a friction fit and a slip fit if i slightly warm it which is perfect, I’ll use a set screw but that won’t misalign anything as it’s such a close fit ……
Weight wise 1600grams at the mo
Kim:
Your engine is really coming along!   :popcorn: :ThumbsUp:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
