Author Topic: Deutz D2 vertical Gas Engine (1895) from Castings  (Read 13909 times)
Offline pirmin
Re: Deutz D2 vertical Gas Engine (1895) from Castings
« Reply #45 on: May 25, 2024, 09:19:40 PM »
okay good to know !
so i am now done with the lapping and it went vbery well. i removed about 35 Microns , maybe 40 Microns, i cant measure so accurate but my Bore mic shows the same value on all spots of the bore .
i used a 5 Micron Slurry i made .
it consisted of
Ether , Oil, % Micron Diaomond Lapping Paste, well mixed
in between i clesaned and charged the lap with a gound piece of steel. i will ad as few pictures later
Offline pirmin
« Reply #46 on: May 25, 2024, 09:23:13 PM »
Your plan is to run cast iron rings?
yes
Cast iron rings. From my experience , as soon u install those rings u get a scratched surface anyway ( i am talking micro scratches )
i maybe will crosshatch my bore now with a Hone, i will ask in a car shop if they have such small cylindrical hones . i was told at that size a crosshatch pattern doesnt realy matter. Heinz Kornmüller never lapped his bore and it had a mirror finish just from running the piston rings in this cold drawn tube i believe . i believe he said a mirorish finish is okay
Offline pirmin
« Reply #47 on: May 26, 2024, 12:34:25 AM »
Pics from the Lapping process
Offline pirmin
« Reply #48 on: May 26, 2024, 12:35:37 AM »
Here u See the charging of the Lap with a parallel i never used
And also a Pic of the Lap while i was running it .
Offline pirmin
« Reply #49 on: May 26, 2024, 12:38:27 AM »
Above you can See the bore before Lapping ,it was Just a cold drawn hydraulic tube. The Bore was already very good at that Point ,only the Marks from the cold Drawing process where visible but in Terms of roundness i was very Happy with IT the way i Received it from Bengs in Germany.
Heinz Kornmüller mentioned to me that He used those tubes Out of the Box ,and they never failed.
After the Lapping i squirt some ethanole Drops in the bore and Made the Second Pic . U can See the Mirror Finish .
I am very Happy with the Result.
Overall 40 microns where removed,and the bore has No taper in it . ( Measured with Mitutoyo 20-25mm three Point bore mic
Offline petertha
« Reply #50 on: May 26, 2024, 04:18:14 PM »
Can you elaborate on your lap? I've only ever seen 2 kinds for internal lapping. 1) a barrel lap like Acro (picture) where the lap OD expands in the middle (like a barrel). 2) where the lap expands as it is displaced up a tapered arbor (various geometry of expansion slits). Unless I missed it, your lap has no slits?
Offline pirmin
« Reply #51 on: May 26, 2024, 04:36:27 PM »
here u can read about the lap ( this design in particular )
https://www.adriansmodelaeroengines.com/catalog/main.php?cat_id=178
« Reply #52 on: May 27, 2024, 06:39:27 AM »
Ramon (Tug) made a very good guide on how to make a lap for Cylinder work on a CI (Diesel) Engine here on site  :praise2:
https://www.modelenginemaker.com/index.php/topic,1908.0.html
Per         :cheers:
« Last Edit: May 27, 2024, 06:42:47 AM by Admiral_dk »
Offline pirmin
« Reply #53 on: May 27, 2024, 01:04:57 PM »
Honestly, I really wanted to make my lap as described in Raymond's articles, but I had already started before I found the article! In the end, I am still pleased with my results. I couldn't measure any deviation or errors in the bore. Next time, I will definitely make my lap following the article's guidance.
Offline pirmin
« Reply #54 on: July 30, 2024, 10:25:03 PM »
Hello Everyone,
Here's a brief Summer Update:
I've begun working on the castings.
The intake casting and the base casting are displayed here with the governor mechanism mounted for testing purposes. After making some minor adjustments and with assistance from our fellow member Dave , I managed to get everything beautifully sorted out.
« Reply #55 on: July 31, 2024, 06:45:26 AM »
Looks Great and sharp  :ThumbsUp:
Per    :cheers:
« Reply #56 on: July 31, 2024, 01:37:38 PM »
Nice progress and beautiful work!
Offline michelko
« Reply #57 on: July 31, 2024, 03:40:42 PM »
looking awesome :cheers:
« Reply #58 on: August 01, 2024, 07:41:17 AM »
Splendid  :praise2:  :wine1:
Offline pirmin
« Reply #59 on: August 01, 2024, 05:59:40 PM »
 :ChineseBow:
Thanks Guys,
Next component should be the Exhaust casting and then i can finaly move on to the Upper bearing Carrier and the Craankshaft ...it will still take me some time with my tiny machines. But i try to keep the Quality up, so I rather have a long lasting build than a crappy looking one
