Taper pins for me, usual to leave some of the small end protruding so they can be driven out and should hold without loctite
So, 3-1/2" gauge Model Locomotive - spring pins or taper pins for holding valve gear together? Why? (The model is Martin Evans' "Ivatt" locomotive that I'm finishing up)Thanks for any thoughts - JohnS.
Also worth noting is that clock makers taper pins are not the same as engineering ones. Can be a steeper 1 in 30.5 taper for the "universal" ones or a touch steeper for Gauged pins and the hole is cut with a broach not a reamer
