Author Topic: 1/5th Scale Denny Improved Ericcson  (Read 10167 times)
Online Michael S.
Re: 1/5th Scale Denny Improved Ericcson
« Reply #30 on: April 02, 2024, 06:49:51 PM »
I congratulate you on this success. A great movement sequence.
Offline redhouseluv
« Reply #31 on: April 03, 2024, 12:20:01 AM »
I love the motion of this engine and the various techniques used to produce it - awesome!
« Reply #32 on: April 03, 2024, 12:27:41 AM »
Congrats on a runner!
She looks great!
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #33 on: April 03, 2024, 11:55:09 AM »
 :cartwheel: :cartwheel: Well Done! The movement is mesmerizing. Will be very interested to see it all glitzed up!
Offline SteamR
« Reply #34 on: April 03, 2024, 01:18:39 PM »
Hello Jason,
this is a great build. The engine will be a piece of jewelry on every steam event and it is a real good runner. Devinitely it needs to slow down its quick-tempered RPMs to match with this oldfashioned engine age.
Regards
Richard
« Reply #35 on: September 04, 2024, 09:42:51 AM »
After the distractions of a couple of other engines I got back to this one to do the last part which was the water pump. Not only is pumping water the main use for these engines but the water also serves to pump the cooling water around the cylinder before exiting to it's final destination.
Looking at photos of full size and the Patent the 1/4 scale drawings were not quite right externally so I drew mine to hopefully be a bit closer to the original, the most noticeable feature that I added was the flange where the bottom of the pump mounts to the main body though mine is a dummy.
I started by facing and then milling two flats along the length of some 1" brass bar so that I had some ref faces to work with and then drilled, reamed and tapped the long holes using the 4-jaw. Then over to the CNC firstly with an adaptive path to rough out from one side.
Then a couple of finishing paths though the majority was done with a scallop using a 3mm dia ball nose cutter stepping over 0.2mm per pass. After that it was flipped over and the other side cut.
The bottom flange was also machined on the CNC before being "parted off" with a slitting saw
The flange and a piece of flat material were then silver soldered to the body, the flat material milled to final size and thickness then drilled along with a few other cross passages. The remaining parts were just turning and a bit of milling to form the hexagons.
All seems to move as it should once assembled, just got to make the pivot pin to replace the 3mm machine reamer I am using in the photo.
I'm undecided about how much plumbing I will do. I generally run my engines for short periods and therefore don't put water in the hoppers so will not really need any water circulating and there is little point in making and fitting dampers when the engine is not pumping to any head or against the restriction of long pipe runs so may just go with a couple of short stubs of pipe. If that is the case then all is ready to start painting.
« Reply #36 on: September 17, 2024, 05:14:02 PM »
The last thing to make was a wooden sled to mount the engine on as it needed to be raised up to clear the camping gas burner body. The CNC makes quite a neat job of mortice and tenon joints
Then a coat of paint, the bed plate and furnace were done in a stove paint, the pumkin orange and dull red flywheel are close to original colours and I gave then a cat of clear matt as it did not want the orange to look too flashy.
It's knocking a bit as I removed the pump's piston so I could blow air into it for cooling so the rod is not being guided that smoothly but otherwise not running too badly.
 <a href="https://www.youtube.com/watch?v=9Aqrgis-lXg" target="_blank">http://www.youtube.com/watch?v=9Aqrgis-lXg</a>
Offline Alyn Foundry
« Reply #37 on: September 17, 2024, 06:10:58 PM »
STERLING work, as usual Jason.
 :cheers:  Graham.
« Reply #38 on: September 17, 2024, 08:00:20 PM »
Beautiful engine Jason!
