Author Topic: a hundred years ago  (Read 1584 times)
Re: a hundred years ago
« Reply #15 on: June 23, 2024, 09:37:15 PM »
Great find!  When do you start the model?   :stickpoke:
« Reply #16 on: June 23, 2024, 09:49:15 PM »
Yes, I would like to build it, but I don't know when I'll do it yet.
There are so many other projects.
Finally, two more pictures of the engine when it came to me.
« Reply #17 on: June 23, 2024, 10:30:14 PM »
Amazing restoration!
Offline Charles Lamont
« Reply #18 on: June 23, 2024, 11:38:44 PM »
Great restoration. I am surprised the lugs on the cylinder casting survived the bending of the support columns. I would call that Marshall valve gear. Hackworth has a slide and die-block, while Marshall* uses a swinging link, which makes for a more durable and quieter gear.
*There are other Marshall valve gears and quite a bit of confusion around them. One was used on later Marshall traction engines and does have a big cylindrical die block that the eccentric rod passes through.
