Author Topic: Reconditioning a Stuart Simplex  (Read 14267 times)
Online redhouseluv
« on: February 06, 2024, 09:09:46 PM »
This will be my 3rd Stuart restoration project, but this ones a keeper........ it's bruised, it's battered and in need of love and attention, however, I may not be able to do it justice atm without workshop facilities........let's see
I never realised how small one of these simplex engines was until it arrived; very cute. It turns over smoothly and I can feel sucking and blowing which is a good sign, but clearly has several issues which need to be addressed
The engine was mounted in order to power a boat, hence the angle. I took it off the base to understand what is out of alignment; just about everything is the answer!  ;D
1. Valve chest cover is larger than valve chest
2. Valve chest top slopes downward from cylinder
3. Valve chest sides taper inwards towards valve chest cover
4. Cylinder base cover/mount looks like someone has gone crazy with a file
5. Eccentric has no bolts appearing from the bottom
6. Small hole in the cylinder base cover/mount
7. Solder between the cylinder and valve chest underneath
7. The inlet valve has been soldered in an 'interesting' way to the valve chest cover
I don't want to replace/correct everything which isn't right - it'll end up being a different engine, so I'm thinking of:
- Making a new valve chest cover which fits the valve chest (maybe a problem as the studs probably go all the way back into the cylinder)
- Maybe a new valve chest if the holes are too misaligned
- Maybe having the inlet coming through the side or top of the valve chest
- Replacing the cylinder bolts with studs/nuts
- Tidying up the Cylinder base cover/mount
- Bolts/studs for the eccentric
- Lagging around the cylinder
- Strip down, cleanup and repaint
Also, is there anyone out there who knows about these little engines:
- Why is it called a Simplex? When I Googled it I got back Simplex Locomotives? What's the connection, if any?
- I'm not sure what sort of lubricator is on it, but I kinda like it  :)
- From what I have read and from the type of crosshead guide this is an earlier model?
- If this came only as a kit or complete what has happened to the poor thing over the last 100 years!
- Slim chance, given the point above, has anyone got a diagram/ drawing?
« Last Edit: February 07, 2024, 12:07:27 AM by redhouseluv »
Re: Reconditioning a Stuart Simplex
« Reply #1 on: February 07, 2024, 07:06:35 AM »
Looks like quite a bit has been soldered together in an attempt to seal uneven surfaces and also the problem of holes coming out the side of the valve chest. May even be due to stripped out threads so it can't be screwed together.
Chest cover looks a different colour so possibly replaced with brass at some time, the boss being soldered on suggests the person did not have  a lathe and just soldered on what they had.
It is an early version without the trunk guide but not sure if the round rod came before or after the flat guide. Not seen one with the mounting lugs on the sole plate, they all seem to have holes passing right through
I looked at a lot when I built my replica but was not able to find a drawing, I'll did out some photos with sizes on them.
Online redhouseluv
« Reply #2 on: February 07, 2024, 10:17:13 AM »
Thanks Jason, most appreciated.
I think you're right about the valve chest and I'm now thinking about undertaking a more comprehensive rebuild when I have my workshop back. I think the solder between the valve chest and cylinder has been place there as the stud has come through at the incorrect angle into the cylinder ....... I will check when dismantling
I have been told the AJ Reeves Trojan engine designed by Edgar Westbury is a close relation (see picture). I've done a quick measure up and think I could use the steam chest and cover from this engine and machine it to size. I will have to either fill the existing holes in the cylinder or make some new ones in a different position
« Last Edit: February 07, 2024, 10:30:57 AM by redhouseluv »
Offline Zephyrin
  • near Paris, France
« Reply #3 on: February 08, 2024, 08:52:37 AM »
A pretty little engine,
on the second picture, the steam chest looks to be too small in height, and alas the top of the cylinder has been filed to cope, this sloping side would require to be amended either by adding metal or resurfacing the top of the cylinder if the top of the piston allows.
I hope that putting all the parts apart will not be too difficult owing to the bruised screw slots, and the soft solder in many places.
And the tap on the steam chest cover should not be after the oiler, but before.
Online redhouseluv
« Reply #4 on: February 08, 2024, 09:27:05 AM »
I agree with your assessment and the tap is definitley in the wrong place.
Regarding the sloping of the cylinder, the adding metal option is my current thinking. I would first make and fit a new steam chest and cover, the gap could then be seen and filled accordingly.
Its difficult to work out what to do and what to leave when restoring an engine of this age. I want to make it look good, function correctly, but without creating a 'Frankenstein' engine?  ;D
« Reply #5 on: February 08, 2024, 10:30:49 AM »
lot of work to make a good one like these.
Probably a job saved until you have the workshop up and running again a smaking new parts and repairing old threads etc is not really  a kitchen table job.
Don't forget it is likely to have Whitworth threads and not BA due to it's age.
Offline Bruno Mueller
    • My Homepage
« Reply #6 on: February 08, 2024, 05:47:06 PM »
My Trojan with slip excentre.
http://mueller-bruno.de/  http://www.bosch-combi.de/   https://www.youtube.com/@Jailguzzi
Whoever talks shit about me behind my back is in the best position to lick my ass.
Greetings from the southwest of Germany.
Online redhouseluv
« Reply #7 on: February 08, 2024, 06:05:48 PM »
All the engines posted above look amazing, and yes, I will need a workshop for even the basic restoration
Started strip down today and this has definitely been built on a kitchen table and by the looks of things using kitchen utensils  ;D
I am no expert, but having built a few engines now, I can tell when something is not right and this is like opening Pandora's box - look at the pictures
Additionally:
No gaskets
No packing in any of the glands
Stirpped threads
The eccentric strap is too big
Conrod holes look all over the show
Solder all over the place
Base plate hacked with a file and not symmetrical
And my personal, the cylinder ports  :D
Its a strange one, as I really don't know where I want to get to with this engine. I think I want to the get the obvious visual things sorted out and I want the engine to have the basics to function correctly, but do I want to machine every component again .........not really. I might as well start from scratch and get it right?
« Last Edit: February 08, 2024, 06:38:26 PM by redhouseluv »
« Reply #8 on: February 08, 2024, 06:57:53 PM »
You may be right, just take measurements, fixing them, and make a new one from bar stock if thats in your wheelhouse. Put this one back together for a comparison next to it!
Online redhouseluv
« Reply #9 on: February 08, 2024, 09:40:06 PM »
And here are the offending parts in their full glory; the valve chest and cylinder after being separated by use of a blowtorch. I managed to get some studs out and others snapped in situ, but that was going to happen.
My current thinking is to fill in the holes and then:
1. Make a new valve chest & cover but use 4 x smaller studs and nuts (8BA) so the nuts don't extend past the cover as before
OR deviating from the original
2. Make a new valve chest & cover but use 8 x smaller studs and nuts (8BA) (see black dots on cylinder)
The only reason for option 2 is there is a stud snapped off in one of the cylinder holes and I've never had much success tapping into JB Weld
Smaller studs would also allow me to move the position of the holes inward............ anyway lot's to think about, but I don't want to end up with 'Triggers broom'!
For those unfamiliar with the term, its from an 80's British sitcom and a scene where 'Trigger claims that he's had his road sweeper's broom for 20 years. But then he adds that the broom has had 17 new heads and 14 new handles' '
'How is it still the same broom' comes the reply'
 ;D
P.S. Jason I think may be correct about the threads, however, it may just be luck, but 6BA fits perfect into the cylinder?
« Last Edit: February 11, 2024, 08:58:58 AM by redhouseluv »
Offline Mike R
  • Ottawa, ON
« Reply #10 on: February 08, 2024, 10:51:17 PM »
I personally like option 2 as I'm not a purist and wouldn't know that its not original to the design, I think it would look more "scale" with 8 studs.
It is also going to be easier to repair as you say.
« Reply #11 on: February 09, 2024, 07:15:44 AM »
I think 8 fixings is overkill for such a small engine, scale does not really come into it as these are 1:1 engines designed for powering pond boats not an attempt to replicate a larger prototype.
One option to keep it looking more original and avoid the old holes would be to use 4 fixings for chest to cylinder placed slightly down and up from what is there now but use CSK screws to retain the chest to the cylinder. Then also tap the 4 corners of the chest for studs to take the cover. That way you are tapping into virgin metal in the cylinder but from the outside it will look like the studs are in the right position.
If you do want to make  a replica at least you have something to measure and they are not too hard to make.
Offline Zephyrin
« Reply #12 on: February 09, 2024, 09:03:50 AM »
wow, this cylinder is in poor condition...
for me, I'll drill the screw holes, and press in a bronze rod soft soldered,  then after a pass under the milling machine to get a nice surface, I'll add a layer of bronze to the top of the cylinder, tin soldered too; then resurface the top of the cylinder and the distribution face.
steam ports need attention too, and this will lead to a new steam valve adapted to the new ports sizes. Yes, it is close to "le couteau de Jeannot", whose either handle or blade are sometimes changed, but always remains Jeannot's Knife.
a new steam chest with thicker sides must be done too with 4 fixing bolts.
Online redhouseluv
« Reply #13 on: February 09, 2024, 10:07:30 AM »
I like the idea of retaining the look and at the same time ensuring the cylinder is retained solidly - thank you for all your ideas, this why this forum is great!
@Zephyrin - I like the fact that there's an equivalent to 'Triggers Broom'!
Look what just arrived in the post - a valve chest and cover for Trojan; after a quick glance, I think they'll work out okay ...... hopefully
« Last Edit: February 09, 2024, 10:13:14 AM by redhouseluv »
Online redhouseluv
« Reply #14 on: February 10, 2024, 02:31:02 PM »
Started cylinder repair:
- Filled in old stud holes
- Built up sloping edge so its now level with top of cylinder
- Filled in where studs had broken through edge of cylinder
