very impressive boiler, nice work, should be very efficient too.the feedwater heater (the tightly rolled tube ?) IMO, seems to be exposed to intense heat, the pump wouldn't cope with boiling water.
Excuse my ignorance on boilers but why doesn't the superheater coil draw steam from the very top of the boiler? Bob
Nice work John, looking good. The feed water inlet pipe, does it just go down and terminate below the water level or does it have a distribution tube running along the length of the steam drum - the plans didn't seem to make that clear, and the longitudinal stay inside the steam drum, how was the attachment to the end caps made, flanged and soldered at each end?The pipe to the pressure gauge, could that be made to have a soldered flange with a joint ring and a loose nut, save you having to buy another gauge? (I sometimes squeek when I walk!!)Chris
SNIPLooking at the picture, wondering why, how, that could happen, wondered if you used too large a burner head, that just gave too much heat to the area? I don't have enough soldering experience to know for sure, but you always need to know the reason why, to learn and to avoid making that same mistake again.SNIPChris
John - having looked at the drawing again I can see that the boiler dimensions are much smaller than I had envisaged looking at the photos, so yes, much less material needed at much less cost! But would stiil like to know the supplier you favour!!!Chris
