Author Topic: Flat 4 Lego Vacuum Engine  (Read 2221 times)
Offline dudeface
  • Dodge Co., WI
    • LVE Forum
« on: December 26, 2023, 10:16:12 PM »
Test running my new (incomplete) engine on 1 cylinder.
<a href="https://www.youtube.com/watch?v=qJReIwl6PEs" target="_blank">http://www.youtube.com/watch?v=qJReIwl6PEs</a>
Miles
It's almost like the faster I spin it, the more times it goes around.....
Re: Flat 4 Lego Vacuum Engine
« Reply #1 on: December 26, 2023, 11:03:51 PM »
That's pretty impressive!  Your Lego vacuum engine works pretty well!  :popcorn: :ThumbsUp:
Offline dudeface
  • Dodge Co., WI
    • LVE Forum
« Reply #2 on: December 26, 2023, 11:48:20 PM »
It should run way better on 4 cylinders. As you can see it needs a huge flywheel, but on all 4 the hope is that it will self start and run without a large flywheel.
« Last Edit: December 26, 2023, 11:52:35 PM by dudeface »
Miles
« Reply #3 on: December 27, 2023, 07:59:59 AM »
Off to a good start  :ThumbsUp: :ThumbsUp:  I look forward to see all 4 cylinders in operation  :)
Offline dudeface
  • Dodge Co., WI
    • LVE Forum
« Reply #4 on: December 27, 2023, 04:32:42 PM »
It doesn't seem to want to run on 4 cylinders. I don't know what's going on.
Miles
« Reply #5 on: December 27, 2023, 05:20:13 PM »
Have you double checked the valve timing?
« Reply #6 on: December 27, 2023, 06:58:46 PM »
Enough air volume from the source for all four? Can you try it on each individually, or on just two?
Offline dudeface
  • Dodge Co., WI
    • LVE Forum
« Reply #7 on: December 27, 2023, 09:18:08 PM »
The valve timing is correct. I got it to run around 250 rpm very briefly, then it stopped. I'm having problems with one extremely stubborn valve hanging open, even after oiling the heck out of it several times with vegetable oil. Of course, the oil managed to get in the studs holding 2 bricks together, and now that particular valve keeps falling apart. It looks good, but I guess it's not a very good design.
<a href="https://www.youtube.com/watch?v=tGyQWuZq76s" target="_blank">http://www.youtube.com/watch?v=tGyQWuZq76s</a>
« Last Edit: December 27, 2023, 09:27:35 PM by dudeface »
Miles
« Reply #8 on: December 28, 2023, 02:33:48 AM »
Interesting  engine I can remember doing similar with Meccano 60 years ago ??!!!!
More R & D required I think ??
Willy
Offline dudeface
  • Dodge Co., WI
    • LVE Forum
« Reply #9 on: December 28, 2023, 07:17:23 AM »
I'll be posting videos of more of my engines soon on my channel. https://m.youtube.com/channel/UCPsBGn-rugOhLVwfh47vQDw
Miles
