Supporting > Engine Ancillaries
interesting carb on the bay
dieselpilot:
You won't get many hits on that carb in particular. You'll find plenty if you look for Webra Dynamix which it's a copy of. Your carb has a "remote adjustable" needle. The lever on the main needle adjusts the mixture with a servo.
https://www.rcgroups.com/forums/showpost.php?p=33740527&postcount=12
steamer:
T
--- Quote from: dieselpilot on November 29, 2023, 02:05:50 PM ---You won't get many hits on that carb in particular. You'll find plenty if you look for Webra Dynamix which it's a copy of. Your carb has a "remote adjustable" needle. The lever on the main needle adjusts the mixture with a servo.
--- End quote ---
Thanks diesel... I've now read some.of that....interesting albeit very complicated!...
But that's why I got.it...to find out...
jcge:
Hope this helps Dave
http://www.webraengines.com/carburetor/dynamix/dynamix.htm
petertha:
Echo what dieselpilot says. I ran them on 0.60 size 2-stroke RC pattern models for a few Webra seasons back in the day. They worked but did require some adjustment learning, not quite as plug-n-play as the typical Japanese carbs. I do remember them being fussier about fuel pressure boost (typically pressure nipple off the tuned pipe or crankcase, sometimes with/without restriction or check valve). But typical aerobatic flying conditions make more demands on carbs vs stationary engines - range of high speed, low speed, transition, varying attitudes & G's resulting in wider fuel pressure swings. Once I went to YS timed diaphragm regulator, I never looked back.
good source for Japan engine parts
https://www.rcjapan.net/
Perry (now Conley) USA
https://www.perrypumps.com/
steamer:
Thanks Peter and Chris wanted to understand the ins and outs to see if it's even possible
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
