Supporting > Engine Ancillaries
interesting carb on the bay
Vixen:
Hello Dave,
The heart of this carb will be the needle taper and jet. If you are thinking about the 917; You will need to be able to measure the needle taper precisely and then reproduce it numerous times. The rest is just precision engineering.
steamer:
--- Quote from: Vixen on November 30, 2023, 04:29:57 PM ---Hello Dave,
--- End quote ---
Yup ...well I'll need to replicate it at least twice!. Right now it's all exploratory. It would be easier to hide 2 carburetors if they looked like part of the Bosch slide valve fuel injection system, so at the very least, I had to at least look at what's available, and what would be entailed to build one...or should I say 2.
Like I've said, I'm thinking 2 carbs, one on each bank of 6. That said I'm trying to disguise it all a bit (10 dummy injection stacks and 2 real carbs for this instance)
I am not considering building 12, or even 4. carbs I think this engine is challenging enough to just get running let alone to that level of complexity.
I may build a non prototypical manifold plenum just to get the engine running and debuged ....then craft something a bit more realistic
One must obey the 11th commandment.....
"Thou shalt not kid thyself!"
Admiral_dk:
Amen :praise2:
Navigation
[0] Message Index
[*] Previous page
Go to full version
