Author Topic: Warrior Double acting twin cylinder steam engine from castings  (Read 18781 times)
Re: Warrior Double acting twin cylinder steam engine from castings
« Reply #135 on: May 03, 2024, 07:30:54 AM »
Looking good  :praise2:
Was it a problem soldering the pipes in place? There must have been a lot of heat loss to the cylinders. I think when Achim (Fumopuc) soldered the pipes on his Snow engine he used thin wire as a spacer to reduce the heat flow.
« Reply #136 on: May 03, 2024, 05:19:35 PM »
Hi , R,  I was worried about that and on the longer curved copper pipe I soft soldier it away from the cylinder block and then soldered the square connecting block in place whilst in position on the engine. I did slacken the bolts on the flange to prevent heat transfer ... and this worked very well . I think the large square brass block helped to keep the heat in that vicinity  ?/ so  worked rally we'll and no problem or difficulty  !!. I am quite aware of various problems associated with engine building but when it comes to doing things ..everything seems to work !!  which is how all these fine working models get made ....
cheers .. just a quick question ...are there tables available to calculate how large the steam pipes need to be to furnish the cylinders with the adequate amount of steam to run them ??
Willy
« Reply #137 on: May 23, 2024, 10:48:58 PM »
Hi All I am still working on the engine making all the gaskets and all the correct nuts and bolts ...also I will be painting it. I will be going to the Strumpetshaw Ralley on Saturday  so that should be fun if the weather is fine ...
Willy
Offline Zephyrin
  • near Paris, France
« Reply #138 on: May 24, 2024, 09:23:17 AM »
nice looking model...the air test is conclusive, great!
on the base, there is a small free place, I guess you'll put a pump ?
« Reply #139 on: May 24, 2024, 10:48:03 PM »
Hi "Z" ,thanks for the reply and I will be putting a brass plaque on the raised platform .  I have also finished the gaskets using this 1/64th material from EKP supplies ...it is green and black so is good to mark out with a black pen...also I have this clock/watch makers punch to make the holes , it is pointed so it can be accurately aligned ..Also a nifty USA screwdriver for holding the 7BA screws to enable them to be position for inserting into the holes without dropping them on the floor !!
Willy
« Last Edit: May 24, 2024, 10:51:17 PM by steam guy willy »
« Reply #140 on: June 11, 2024, 12:53:42 AM »
More work on the engine ...lots of cleaning up , gasket fitting on painting.  I have been using Sable haired brushes .. this are quite expensive but they do last a long time ...they are quite soft and are made locally just up the road in Lowestoft ......still more to do for final cleanup and tidying up the steam connections..Also much work to do in the allotment.  also I will be going to the Midland exhibition on the Saturday and will help out on the stall but as Norwich club transport docent get there till about 11 am I won't be able to bring any models   however I have lots of room in my bag for small tool items ?!!!!  so it will be good to see some of our members !!
Willy
« Reply #141 on: June 11, 2024, 01:01:49 AM »
I have attached the steam pipes and did this with the unpainted and ungasketed model .....however when I attached the 2 X  1/64th gaskets the fitting of the steam pipes was quite difficult as the steam chest are now 1/32nd apart  ?!! this will be sorted hopefully ...
Willy
« Reply #142 on: June 11, 2024, 01:29:21 AM »
In the pictures with paint, looks like the only screws holding the frames to the base are on the outer sides, that tilting them some?
« Reply #143 on: June 11, 2024, 02:59:15 AM »
Hi "C"  yes , well spotted, there were only 4 screws screws on the standards but there were also 4 pins holding them in the correct positions , one for each leg  so this should have secured them in position .and the screws were placed diagonal across the standards so I thought these should temporarily be OK , Thanks for the observation and I will think a bit more about this , also the cylinders will be touching each other and the painted pics were just placed on the base plate for the latest photos ...
cheers
Willy
« Last Edit: June 11, 2024, 03:06:08 AM by steam guy willy »
Online Admiral_dk
« Reply #144 on: June 11, 2024, 06:37:30 AM »
Nice paint job Willy  :ThumbsUp:
The pins will locate the 'Feet' - but not completely prevent a slight angle above them ....
Per       :cheers:
« Reply #145 on: June 11, 2024, 08:42:06 AM »
Hello Willy,
the finish of the green color looks good.
The fact that the holes for the pipe are now a little further apart is of course annoying. But the copper pipe is soldered in with soft solder. It looks like this. Maybe you can heat the pipe again in one place and you'll gain half a millimeter.
Greetings Michael
« Reply #146 on: June 11, 2024, 08:40:33 PM »
Greetings Michael
[/quote]
Hi Michael thanks for the advice and I do need to add .79 mm as the gaskets have gained  1.32"  !! but yes applying heat will work  Thanks
Willy
« Reply #147 on: January 03, 2025, 10:28:33 PM »
Hi All I have now completed the engine and placed my Monica on the engine bass plate that was reserved for the boiler feed pump. This was later etched and was done without removing any parts from the 2' tall high laser device ?!! I have now restarted on the Bolton Bertinat triple expansion engine that I began on this site in 2014 ?!!!
cheers
Willy
« Reply #148 on: January 04, 2025, 01:08:39 AM »
It is so easy to forget about our members, and it is great to see an update from you!
Congrats on finishing the twin.  :ThumbsUp:
« Reply #149 on: January 04, 2025, 01:12:57 AM »
Great to see you back Willy!
