Pogo :I do not post a lot here anymore. Work has been crazy the last few months. Not a lot of hobby time. I scanned this thread and decided to give a little advice. This is a hobby not Production work, or a race so work at a pace that is right for you. Secondly expect to make practice / test pieces. I learned many years ago it is a good idea to have a source for hardware before you drill and tap. When making multiple parts with Mutiple setups start out with an extra blank or two. there is nothing worse than blowing a tolerance on a part last step and then having to go through all the steps to make one part. Blondie hacks You tube channel just finished her tender. she also did her boiler so a good resource. some do not like her humor but in my humble opinion worth the watch if you have the time. I think the thing I like best about her is her honesty she shows her blunders as well as her many successes. Nice work you are proving this stuff can be tried at home and one does not have to be a professionally trained machinist. Although it does help at least a bit. tin
