Author Topic: 1/3 Scale Austin Seven  (Read 11365 times)
Re: 1/3 Scale Austin Seven
« Reply #15 on: September 21, 2023, 05:25:25 PM »
Wow, that looks neat!
Offline Austin Seven
« Reply #16 on: September 21, 2023, 06:57:49 PM »
Head and rad back on.
« Reply #17 on: September 23, 2023, 02:03:13 AM »
I just wanted to chime in here and say that engine is a beautiful machine!
Offline petertha
« Reply #18 on: September 23, 2023, 07:34:25 AM »
Very nice. I look forward to any build pictures. Can you provide an overview of the ignition system?
« Reply #19 on: September 26, 2023, 07:13:16 PM »
Hi petertha,
The ignition system is by 4 magnets on a disc in the distributor acting on a hall effect sensor. That is connected to a control module from Minimag Co. I've added a pencil to get scale.
« Reply #20 on: September 26, 2023, 08:06:03 PM »
That's a lovely and authentic looking engine; very well done! The "SU" carb looks the part too! :ThumbsUp: :ThumbsUp:
« Reply #21 on: September 27, 2023, 07:19:46 AM »
Great details  :praise2:
It kind of looks like it has been running for a while - when I look at the Distributer ....
Per        :cheers:
Offline A7er
  • Cornwall, UK
« Reply #22 on: September 27, 2023, 09:35:22 AM »
I can just make out a horizontal line on the side of the cylinder head. Is this a join where the head was cast as two parts, or a (very neat!) casting line?
The detail in this engine is amazing. The LUCAS name on the dynamo is perfect. If you post a video on utube please let us know.
Offline pgp001
  • West Yorkshire - UK
« Reply #23 on: September 27, 2023, 01:07:43 PM »
Having built a few full size A7 engines for my RTC Special in the past, I can honestly say that this is one of the nicest and true to prototype model engines I have seen for a long time.
In fact it is right up there with the ones Mike Sayers produces in my opinion.
Phil
« Reply #24 on: October 08, 2023, 08:49:08 AM »
The head is made from two bits of plate with the waterways machined and then bonded together with dowels. The outside is then machined.
Here are some pictures of the build.
Offline michelko
« Reply #25 on: October 08, 2023, 10:33:13 AM »
So beautyfull parts :cheers:
« Reply #26 on: October 08, 2023, 05:14:56 PM »
Wauh - it's getting better and better  :praise2:
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #27 on: October 08, 2023, 05:24:56 PM »
All I can say is WOW!  Incredible workmanship!
Offline petertha
« Reply #28 on: October 08, 2023, 09:18:08 PM »
Beautiful parts! Can you tell us a bit about the crankshaft? Assume its from solid? - material, turning operations, grinding/lapping... Did you have any post-machining distortion issues to contend with?
Offline pgp001
« Reply #29 on: October 09, 2023, 10:29:59 AM »
It looks like it might be based on a Phoenix crankshaft ?
