Author Topic: Squint Scale Curtiss Model K Aero I4  (Read 50429 times)
Re: Squint Scale Curtiss Model K Aero I4
« Reply #435 on: September 19, 2024, 03:12:36 AM »
Ron,
That engine is quite a sweet sounding one! Great work on the crank and the addition of a third main. My thoughts on the outside two cylinders not running are along the direction of previous suggestions, and that maybe the two carb setup would test that.
Offline john mills
« Reply #436 on: September 19, 2024, 10:02:19 AM »
great to see you have got the engine running again the work has been well rewarded.
is that the car beretta on one end of the inlet manifold would that make the first cylinder to rich an the last cylinder to lean
john
« Reply #437 on: September 19, 2024, 12:34:48 PM »
I'm very happy that the engine is running so well and since you've had success with it, it encourages me to get my flame eater, which doesn't run for me, back on the workbench.
  • Oregon
« Reply #438 on: September 20, 2024, 01:17:24 AM »
Thank you all for the kind comments, and for the suggestions, all of which are read, noted, and appreciated. :cheers:
