It know its my engine, but I want to look correct..... how much latitude do I have?
SNIPThe Roy Amsbury design in Simplyloco's post looks like a Great Western injector steam valve, not really comparable with a cylinder drain cock. SNIP
I have a question that is related to this thread, what is the effect, if any, on the engines performance - theoretical or real - from having the extra dead space in the drain tubes for remotely located drain cocks?
Quote from: Mike R on June 06, 2023, 11:12:02 PMI have a question that is related to this thread, what is the effect, if any, on the engines performance - theoretical or real - from having the extra dead space in the drain tubes for remotely located drain cocks?Once you've exhausted the water through the pipes and closed the valves, the residual steam will likely condense, so the pipes will end up full of incompressible water - so no lost volume.Wilf
Steamer, thanks for those photos. That somewhat validates using the crown hand wheel type valve. I like the look of those handles, looks antique as they should. I might try casting some like that.
