6 thou is a lot to lap/hone. I finish my cylinders with Acrolaps and diamond paste but that requires an ultrasonic bath for cleaning afterwards.Is that a model traction engine I see in the background of the first picture?
It's just a case of mounting the blank on a rotary table and machining a flat to each dimension as you index it around each angular step then blend with a file.
