Author Topic: New lathe cross-slide  (Read 2373 times)
Offline springcrocus
    • Steve's Britannia
« on: April 23, 2023, 10:00:54 PM »
Lathe cross-slide (Part 1)
The cross-slide on my lathe, a clone of the Denham Junior, doesn't really provide a means of mounting a vertical slide because the whole thing is too tall, although the circular tee-slot does provide direct mounting and swivelling for the compound slide. The one advantage the lathe does have, however, is the ability to remove the whole slide very quickly by undoing two coverplate screws and two leadscrew fixing screws.
Needing to machine the saddle of the chimney for my loco, I decided to make a new cross-slide for my machine which would allow for direct fixing of alternative tooling and a vertical slide. The dovetail section is 1/2" high so I reckoned that the table needed to finish at 6" long by 5" wide by 1.1/4" deep. A colleague on the mainland, Simplyloco, offered me a large lump of iron that he had kicking around (thanks, John) but an even better offer came from another of our members on here. After an exchange of PM's, this turned up in the post a few days later.
After setting up in the 4-jaw chuck on the lathe, the two faces were cleaned up and finished about ten thou oversize, them the edges were squared and finished to size in the mill. I don't have a vice large enough to mount this workpiece flat so all subsequent operations were done with the work mounted directly to the mill table. First of these was roughing out the underside, followed by milling the slots for three tee-channels with a 10mm carbide end mill. Having a table feed was an absolute godsend as this took quite a few hours of cutting.
Next, a 12mm diameter tee-slot cutter was passed up and down each channel, setting over to 1.1mm for the first pass and 2mm for the second, finishing with a 16mm wide slot. I have deliberately made the slot-spacing assymetrical to allow for a wider range of clamping solutions.
Next I drilled and tapped a large quantity of M8 boltholes, again using different patterns for greater options.
Clamping the work to machine the dovetail was always going to be problematic because it's neary as wide as my mill table. The power of the cut will be a bit too heavy for cam-button clamps. I got round this by modifying four clamps so that the tongues would fit into the tee-slots, then turning a length of angle iron into an extension of the table by bolting it to the front where the stop collars fit. I did have to dismantle the table feed operating arm to get it to fit but I was still able to use the feed by operating the lever between the microswitches.
This is the cross-slide mounted on the table and the dovetail cutter ready to do it's work. It's a left-hand cutter so I have to run the machine in reverse and cut left-to-right. A friend lent me the cutter for which I've had to make a mandrel because I couldn't use his 2MT mandrel. I made one with a 16mm diameter stem to hold in a collet; my mill has an R8 spindle.
There has been quite a lot of hours needed to get this far but I've been able to get on with other jobs once I've set the cut running. More on this next week.
Regards, Steve
Member of a local model engineers society
www.stevesbritannia.co.uk
Re: New lathe cross-slide
« Reply #1 on: April 24, 2023, 12:04:15 AM »
Looks like a very nice start to your new cross slide, Steve!  :ThumbsUp: :popcorn:
« Reply #2 on: April 24, 2023, 12:06:39 AM »
You wont regret it either.   I've found my T slotted cross slide to be very useful!
Offline Chipswitheverything
« Reply #3 on: April 24, 2023, 09:10:47 AM »
Very impressive machining that is getting a bit towards the industrial side of model engineering in chewing metal off!  Looks as if the iron block was of nice machining quality.  A good project which will be most useful when completed.   Dave
    • Steve's Britannia
« Reply #4 on: April 24, 2023, 11:12:12 AM »
Kim, Dave and Dave, thanks for your comments.  :cheers:
 It has been lovely material to machine, most probably Meehanite. Lots of black dust, the Mrs was complaining that I was coming indoors looking like a coalman.  :Lol:
 Regards, Steve
« Reply #5 on: April 24, 2023, 12:08:03 PM »
Interesting Project and clamping solution  :ThumbsUp:
Per   :cheers:
    • Steve's Britannia
« Reply #6 on: May 03, 2023, 11:30:07 PM »
Thanks, Per.
Lathe cross-slide continued
Before setting up to mill the dovetail, I trammed the head. These mills are notorious for going out of alignment after heavy use in the same direction because there is no locking dowel to keep the head aligned at 90o to the table. My mill is the UK version of the Grizzly G0704. I knew it needed doing because I was getting tail-cutting when sending the tool left-to-right. After cutting the dovetail, the workpiece was offered up to the lathe to check the clearance over the centre section and a 10 thou feeler fits in there quite nicely.
The jib strip was next and I made this from a piece of 1.1/4" diameter cast iron bar, milling it down to form a flat bar 3/4" wide by 1/2" high. I set up my angle table to exactly 30o by clocking out on an angle gauge.
Next, a fence was clamped to the top, clocked square and the work fixed to the fence using a pair of engineer's clamps. The work needed to be on and off the fixture a number of times until a nice, sliding fit was obtained and this seemed the quickest and easiest way to mount the work.
The jib strip was faced to length, then a pair of recessed holed were drilled to take M5 cap screws and the jib strip lightly clamped the underside of the table. The centre of the five jib-adjusing grub screws was replaced with a long caphead screw to act as table lock. Also drilled and tapped were the two holes for the leadscrew block and the holes for the bedway cover.
And, finally, a picture of the new table ready to carry some tools. It takes less than two minutes to undo this one and replace the original cross-slide so I expect to be swapping between the two on a regular basis.
Regards, Steve
Offline BillB
  • Jr. member
« Reply #7 on: May 04, 2023, 01:26:21 AM »
Very nice job Steve!  I need to do the same thing.  There is a chunk of cast Iron in the cabinet under my lathe that has been waiting for a few years.  Each time I thought about doing it I could not decide between T-slots and tapped holes.  It never occurred to me that you could do both :Doh:
I also have the same style mill as you and have been trying to figure out how to add a quill stop.  It looks like you have one mounted on the bracket for the digital readout.  My bracket is made of plastic but after seeing yours I'm thinking I could re-make that part out of steel and copy that idea too.
Now all I need is an extra year or so to get all the shop and house projects done so I can get back to the engines ;D
-bill
Offline Bruno Mueller
    • My Homepage
« Reply #8 on: September 18, 2023, 09:58:11 AM »
I made a cross slide for my second Bosch Combi lathe a few years ago. The original slide was unfortunately missing when I purchased this lathe.
I measured the original cross slide of my first machine and made drawings.
The actual slide carrier, which is attached to the bed, I initially wanted to make from a welded construction.
I also learned to weld at some point in my younger years. However, I lack the necessary practice.
I then milled the carriage carrier out of a full gray cast iron block.
The rest was made from bright steel.
I got some of the material I needed from my own stock or from my steel dealer.
I started by measuring the original cross slide.
Then the necessary drawings were made.
All drawings were made with pencil on paper. I never learned to make drawings with CAD programmes.
Here the original cross slide.
http://mueller-bruno.de/  http://www.bosch-combi.de/
Whoever talks shit about me behind my back is in the best position to lick my ass.
Greetings from the southwest of Germany.
    • My Homepage
« Reply #9 on: September 18, 2023, 10:01:36 AM »
Some of the drawings for this.
    • My Homepage
« Reply #10 on: September 18, 2023, 10:16:32 AM »
When machining drawn bright steel, the steel must be machined from both sides. If the material is removed from one side, the part will warp due to the internal stresses. The milling work was carried out in stages from both sides and the material was left to rest for one night between each machining stage. This way I was able to eliminate the deformation.
Face slide premilled.
« Last Edit: September 18, 2023, 11:47:54 AM by Bruno Mueller »
    • My Homepage
« Reply #11 on: September 18, 2023, 10:22:49 AM »
Pictures of the production of the cross slide carrier made of grey cast iron.
    • My Homepage
« Reply #12 on: September 18, 2023, 11:40:45 AM »
Bottom part of the top slide.
    • My Homepage
« Reply #13 on: September 18, 2023, 11:43:43 AM »
The top slide.
    • My Homepage
« Reply #14 on: September 18, 2023, 11:51:03 AM »
Assembly.
