Looking good.What other improvements are you going to carry out? I fitted DRO's to mine.Colin
I could provide you with detail photos and dimensions of the lever tailstock feed arrangement on the CW90 version.I've also developed a design for a quick-release half-nut for carriage traverse, if that's interest. The design has been made and test-installed on my CW90 and works well.
Yes please, we all would appreciate those Jo
Now that we are discussing modifications to the ME90, has anyone ever fitted a carriage lock? I've been doing some heavy-ish work on mild steel with a HSS tool with a fair bit of top rake and I found that the tool was being pulled into the work when facing across the work, giving me quite a concave cut. I suspected that this was being caused by the carriage moving with the play on the leadscrew. It could also have been movement of the top slide as well. This was causing me a fair bit of difficulty facing to a precise dimension.I've thought about replacing the centre gib adjusting screws on both the carriage and topslide with cap screws and using them to apply locks when cutting. Any thoughts?Jim.
If you aren't already too far along on the job for it to be of help, I could provide you with detail photos and dimensions of the lever tailstock feed arrangement on the CW90 version.SNIP
Hi JimIf you look at the first picture in my last post you will see a small hole in the saddle directly above the tee slot in the bed. This takes a screw and nut which locks the saddle. It may have been put there by the previous owner, but it works!
Hi Harry. I've already started the conversion. I look forward to seeing your designs!RegardsJohn
Quote from: simplyloco on April 08, 2023, 09:07:33 AMHi JimIf you look at the first picture in my last post you will see a small hole in the saddle directly above the tee slot in the bed. This takes a screw and nut which locks the saddle. It may have been put there by the previous owner, but it works!John,I've got the same hole on my saddle and it was put there by Cowells. I've always assumed it was for a swarf guard since I have a similar hole in the same place on my Myford saddle which is used to hold a swarf guard. The hole looks to be threaded so I'll find a cap screw for it and try it out. It should work and it would avoid messing around with gib screws. But I'll probably have to replace a gib screw to lock the topslide.Jim.
Nicely done John. Here FYI is Mssrs Cowells version. It has a relatively short stroke as you can see from the pivot arm length.As for the cover . . . if it were mine I would paint it, HOWEVER . . being plastic (or something other than metal) I'd also expect it to show wear and chip more easily than metal. In the end, make yourself happy.
It'll be a shame to get it covered in swarf and cutting oil. Jim.
If you're not goint to use it - will it get a DisplayCase to reside in
Quote from: Admiral_dk on April 11, 2023, 07:15:29 PMIf you're not goint to use it - will it get a DisplayCase to reside in He'll sell it Jo
That looks very nice.Did this originally have the push buttons, or have you upgraded from the single forward/reverse on/off switch. If so was it an easy upgrade.Colin
Dials looks great and you are going to be happy about improvement of the Collet-Holder for years to come Per
Yikes! They're pretty proud of those, aren't they? I like the ones YOU made! They look like they'll do the job nicely! Kim
John,I haven't forgotten I promised to post dwgs and info on my half-nut conversion, and will when the glut of Spring chores has subsided. Here's a schematic of the job.SNIP
I don't have the Cowells lathe anymore. It's gone to a good home!Before anyone asks how much I got for it: I gave it away to a friend who needed it more than I did...
Quote from: simplyloco on June 30, 2023, 11:44:00 AMI don't have the Cowells lathe anymore. It's gone to a good home!Before anyone asks how much I got for it: I gave it away to a friend who needed it more than I did...And lets guess the friend felt the need to provide you with a fist full of holiday tokens Jo
JohnI admire your generosity. Is the recipient of the next generation? The young need a lot of encouragement these days.Anyway, I hope the new owner makes good use of it.AVTUR
Quote from: Jo on June 30, 2023, 12:21:31 PMQuote from: simplyloco on June 30, 2023, 11:44:00 AMI don't have the Cowells lathe anymore. It's gone to a good home!Before anyone asks how much I got for it: I gave it away to a friend who needed it more than I did...And lets guess the friend felt the need to provide you with a fist full of holiday tokens JoYou guessed wrongly Jo. Please read my post again where it says I gave it away. Yes, I G A V E it away, no strings or conditions.John
Quote from: simplyloco on June 30, 2023, 12:33:24 PMQuote from: Jo on June 30, 2023, 12:21:31 PMQuote from: simplyloco on June 30, 2023, 11:44:00 AMI don't have the Cowells lathe anymore. It's gone to a good home!Before anyone asks how much I got for it: I gave it away to a friend who needed it more than I did...And lets guess the friend felt the need to provide you with a fist full of holiday tokens JoYou guessed wrongly Jo. Please read my post again where it says I gave it away. Yes, I G A V E it away, no strings or conditions.JohnYou will have to give us the Ebay number so we can see how much it sells for. Jo
Quote from: Jo on June 30, 2023, 01:19:04 PMYou will have to give us the Ebay number so we can see how much it sells for. JoReally Jo, you shouldn't judge people by your own standards...
Stick it in your boot tomorrow and I will pop to guildford
