those will be a a pair of supper precision angular contact ball they will come as duplex pair the single would be a super precision deep groove .i just replaced the ones in my mill it has two pairs.john
17 ID 30 OD 7mm wide, at least that is what I'm finding on the NET. The DIN 625 seems to point to a deep groove high speed bearing that can take both redial and axial forces.I don't think that I saved the old ones.Dave
I did find the originals and the dimensions are correct, the Deckel only has two bearings on the spindle, one at each end. The other one is 12 ID 28 OD and 8mm wide.Dave
