Hi DaveIt will be fun to follow along with the rebuild.I picked up the one in the attached photo last year and went completely through it. It wasn't in too bad of shape just filthy.New bearings in the spindle and motor and new felt seals in the work head and main bar. I did have to make a few small parts that were missing and not available anymore.I'm pleased to have been able to acquire it and the price was right too. Dave
the gorton book i have mentions a work head for doing radius ball end cutters do you have a gorton book the one for there milling machine gives some instructions for grinding D bits.I found the cutters need to be precise to work well .when i made a lot of embossing dies you soon found some that were ground and held so they run true worked well some would not last long at all and i would get they weren't quite right.at that time i could only use a tool and cutter grinder and the better chuck was missing.I only worked out what to grind an engraver showed me what they used.John
