Author Topic: Clarkson twin compound query.  (Read 934 times)
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« on: March 25, 2023, 09:08:00 PM »
Hi all.
I may be able to purchase a set of castings to make a Clarkson twin compound steam engine, it's fairly large engine for hobby equipment so I'm wondering it it can be made on a Chester DB10 lathe and Chester Champiom 20 Mill?
Anyone able to offer any thoughts please?
Re: Clarkson twin compound query.
« Reply #1 on: March 25, 2023, 09:12:41 PM »
Horizontal or vertical engine? The horizontal is small enough to be made on a hobbymat.
Offline Gas_mantle
  • North Yorks - UK.
« Reply #2 on: March 25, 2023, 09:25:49 PM »
Thanks, it's the vertical twin compound marine engine.
 I don't know the full dimensions but it is 2" and 1.25" bore so it's a fair size for my tooling.
Online Jasonb
« Reply #3 on: March 26, 2023, 07:15:18 AM »
I would have thought so,  I expect many were done on a Myford with a vertical slide for milling. The two cylinders are separate castings so not too big to bore in the 4-jaw and the flywheel is not massive as it's a marine engine. Largest parts for milling would be the bed and standards but should be within what your machine can do.
Best bet woul dbe to get the drawings from Blackgates and have a look through them first.
« Reply #4 on: March 26, 2023, 07:50:09 AM »
The flywheel on the Vertical Compound is 150mm, the Chester Lathe mentioned has a 250mm swing.
Offline Gas_mantle
  • North Yorks - UK.
« Reply #5 on: March 26, 2023, 12:22:17 PM »
Many thanks, I'll have a think about it.
The kit comes missing a few part, the box bed being one but think the parts missing should be easily fabricated if they are no longer available to buy.
Online Jasonb
« Reply #6 on: March 26, 2023, 04:16:40 PM »
Blackgates may well be willing to cast individual parts but something like the box bed is reasonably easy to fabricate, could even make it more like a typical marine engines sole plate and cut from solid aluminium plate and mount on a couple of timers to get the flywheel clearance
Offline Gas_mantle
  • North Yorks - UK.
« Reply #7 on: March 27, 2023, 11:23:58 AM »
Thanks, I'll have a think about it  :)
Online Jasonb
« Reply #8 on: April 02, 2023, 07:03:35 AM »
Went for a very reasonable £205 though looks like not to you.
Offline Gas_mantle
  • North Yorks - UK.
« Reply #9 on: April 05, 2023, 10:25:24 AM »
Hi Jason, I considered making a bid but decided against it, I've bought castings for a Stuart beam engine that is probably an easier build for me.
