Author Topic: Stuart “Minor” Beam Engine Build, 12 years and counting  (Read 7179 times)
Offline Chipswitheverything
Re: Stuart “Minor” Beam Engine Build, 12 years and counting
« Reply #45 on: April 01, 2023, 08:59:55 AM »
Very nice work done on the good looking con rod, and the lagged cylinder looks very smart too.  This build with attention to extra detail is really getting the best from the smaller sized Stuart beam engine.  Dave
« Reply #46 on: April 01, 2023, 01:12:31 PM »
Looking good  :ThumbsUp: :ThumbsUp: I like the connecting rod and cylinder lagging  :)
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #47 on: April 01, 2023, 01:51:10 PM »
This build is looking very nice. I love the mods you have done.
« Reply #48 on: April 01, 2023, 04:11:33 PM »
Well done!  The dark lagging and the bright brass look good together!  :popcorn: :popcorn:
Offline Djangodog
« Reply #49 on: April 02, 2023, 01:45:37 AM »
Thank you all for the kind comments.
Spent the day making the piston, piston rod, spacers and shafts for the parallel motion.  It works as it should.  Stuart did not allow for clearance in their dimensions, so if you make everything at the mean, you will have some interference.  Removing a little material from the excess lengths of thread takes care of any issues.  The slide valve and linkage are next. I still need a base, some paint and I want to reduce the size of the heads on the 2BA screws and of course make some gaskets.
« Last Edit: April 02, 2023, 03:57:58 AM by Djangodog »
Offline Charles Lamont
« Reply #50 on: April 02, 2023, 09:35:07 AM »
It's all looking very nice. I think the lagging looks spot on.
Offline Djangodog
« Reply #51 on: April 03, 2023, 01:45:52 AM »
The slide valve and valve related parts are machined and in place.  The last part, (three parts), will be the rod that actuates the valve mechanism.  The engine should be ready for a test run on Tuesday, then it will be dismantled and finishing touches made.
Offline wagnmkr
« Reply #52 on: April 03, 2023, 04:17:41 PM »
You are cracking right along with this!  It is looking very good. You have reminded me I need to give the beam engine diorama a dusting. Of course, I get to play a bit as well. :cartwheel: :pinkelephant: :cartwheel:
Offline Djangodog
« Reply #53 on: April 05, 2023, 01:01:03 AM »
It lives!  I mounted the engine to a nice piece of Cherry and tested it.  The steam chest gaskets are in place, but it was run with no rings, no cylinder gaskets and no gland packing.  Despite that, it ran fairly well on 15 psi, and less and it sounds much better in person  I did not run anything in.
It’s time to tear it down and make some finishing touches and add some paint, gaskets and gland packing.
<a href="https://www.youtube.com/watch?v=Y04ryZvgBJ4" target="_blank">http://www.youtube.com/watch?v=Y04ryZvgBJ4</a>
« Reply #54 on: April 05, 2023, 01:10:09 AM »
Congrats on a runner. She sounds and looks great!
« Reply #55 on: April 05, 2023, 01:30:37 AM »
Runs great even without the  gaskets and such,  going to be even better with them! Great work!
« Reply #56 on: April 05, 2023, 04:52:29 AM »
Very nice!  So fun to see it run, isn't it!  :ThumbsUp: :popcorn:
« Reply #57 on: April 05, 2023, 09:10:52 AM »
Gongrats - a very fine runner - even without the packing  :praise2:
Per    :cheers:
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #58 on: April 05, 2023, 01:10:33 PM »
Congratulations.
That turned out very well. I will be watchig for the final version.
Thank You for posting.
ShopShoe
Offline Djangodog
« Reply #59 on: April 05, 2023, 02:46:02 PM »
Congratulations.
ShopShoe
I appreciate all the comments and encouragement.  A governor may be added later, but it won’t be a Stuart governor, (it will be smaller and probably use bevel gears).
The weather forecast sounds like Sunday will be a good day for painting.  That gives me some time to get things ready.  It was nice to see it running.
