Author Topic: Stuart “Minor” Beam Engine Build, 12 years and counting  (Read 7175 times)
Re: Stuart “Minor” Beam Engine Build, 12 years and counting
« Reply #60 on: April 05, 2023, 04:23:03 PM »
Awesome another runner
Offline Djangodog
« Reply #61 on: April 08, 2023, 05:10:54 PM »
Here she is, (not complete, but the governor and better plumbing can wait).  I told my wife that this one would not be Stuart green and black, but that is not the case.  The base casting looked nice in its natural state, so at least for not, it will remain bare.
« Last Edit: June 03, 2023, 01:17:20 PM by Djangodog »
« Reply #62 on: April 08, 2023, 05:55:24 PM »
Fantastic!   :ThumbsUp: :ThumbsUp:
« Reply #63 on: April 08, 2023, 05:59:53 PM »
Beautiful!  The colors look great  :ThumbsUp: ;D
« Reply #64 on: April 08, 2023, 06:24:58 PM »
I really like the red stripe on the flywheel.
You have built a very well done model.
« Reply #65 on: April 09, 2023, 09:46:14 AM »
Splendid  :praise2:  :praise2:  :wine1:
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #66 on: April 09, 2023, 11:26:55 AM »
A good looker and a good runner. :cheers:
Offline Djangodog
« Reply #67 on: April 21, 2023, 12:33:02 AM »
Here is an image of my governor prior to setting up the bell cranks and linkage. Unfortunately, small governors aren’t effective at low speeds, so I ran the engine a bit fast to show the function.
Stuart beam engines have 1/32” side to side clearance between the connecting rod bushing and crank pin which makes an annoying clacking sound.  I will be making a new bushing with minimal side play and eventually running a flat belt to bevel gears for the governor.
The governor is based on the Stuart Watts Governor.  The balls and manifold are scaled down by 20%, the arm length increased by .125”, the spring replaced by a weight and the hardware is my own.
I’m fairly happy with it, but it remains a work in progress.
The second picture has it in its home.  It is kept in an antique barrister bookcase to keep it clean.  The environment in a wooden case is nice and stable so oxidation should be minimal through the years.
« Last Edit: June 03, 2023, 01:18:48 PM by Djangodog »
Offline Djangodog
« Reply #68 on: April 22, 2023, 01:30:02 AM »
I made a new connecting rod bushing with minimal side to side clearance and it quieted the engine down.  I also ran it at approximately 4 psi.  I still want to add a regulator and dedicated air line.
I’ve enjoyed the project and adding some personal touches and I am grateful for the encouragement and comments along the way.
« Last Edit: June 13, 2023, 03:37:31 PM by Djangodog »
« Reply #69 on: May 19, 2023, 01:31:35 AM »
Very nicely done!    :ThumbsUp:
Offline wagnmkr
« Reply #70 on: May 19, 2023, 11:29:19 AM »
Another lovely beam engine completed. It is a very good looking machine :cheers:
Tom
« Reply #71 on: May 19, 2023, 12:18:04 PM »
Love the finished look  :cheers:
Offline Zephyrin
  • near Paris, France
« Reply #72 on: May 19, 2023, 02:10:47 PM »
beautiful engine, runs well too, congratulations !
does this nice bucket is made for collecting exhaust condensates and oil ?
Offline Djangodog
« Reply #73 on: May 19, 2023, 05:38:07 PM »
Thank you all for the comments.
The bucket is there to collect exhaust oil and to add a little to the engine visually.  I had some leftover thick walled bearing bronze tubing and some Mahogany hanging around, so I made it up.  There is a stepped Brass plug at the bottom and it has a .375” long by .500” diameter protrusion to locate it into the wooden base, (it lifts out for cleaning).  I will ran lines from the drain cocks to the bucket in case I ever decide to run it on steam.
<a href="https://www.youtube.com/watch?v=GrBypFjFlJE" target="_blank">http://www.youtube.com/watch?v=GrBypFjFlJE</a>
« Last Edit: June 13, 2023, 03:34:02 PM by Djangodog »
