Author Topic: workbench in the works..  (Read 3588 times)
Re: workbench in the works..
« Reply #15 on: March 10, 2023, 01:53:59 AM »
It needs a  holdfast shaped like Slims arm and hand!
Offline tghs
« Reply #16 on: March 10, 2023, 02:01:27 AM »
thats twisted,, I like it :cheers:
what the @#&% over
Offline tghs
« Reply #17 on: March 16, 2023, 10:54:22 PM »
the little bench is about ready for service,, the dowel vise handles will get replaced with some turned hardwood,, have to order up some longer 3/8ths brass bolts that will quickly turned and milled into the bench dogs..
what the @#&% over
« Reply #18 on: March 17, 2023, 12:57:54 AM »
Looks great!  Very similar to my full size one except not covered in carving chisels, chips, dust, dents...
« Reply #19 on: March 17, 2023, 12:02:13 PM »
I'm kind of in between in the looks department - yes it looks too shiny - but I would prefer that it never reaches the stage mine is in .... as I know my grandfather would never allow it to look as it does today - when he was alive  :-[   :embarassed:
But I would suggest an oil finish to protect the wood + and the rest will come with use  ;)
Enjoy using it, as the Tool it is  :praise2:
Offline tghs
« Reply #20 on: March 20, 2023, 08:41:27 PM »
turned some 3/8ths brass bolts into some bench dogs, round off the heads, mill the flat, take the shaft down to 11/32nds, cut to length,, fast and cheaper than large brass rod!!!
what the @#&% over
« Reply #21 on: March 21, 2023, 03:31:56 PM »
Love it…. :Love:
Offline tghs
« Reply #22 on: March 22, 2023, 05:06:25 PM »
gave the bench a quick coat of tung oil, found a drawer unit that will fit nicely and should work out well https://www.amazon.com/dp/B084QCXZ7C?psc=1&ref=ppx_yo2ov_dt_b_product_details
the little router table top arrived and looks like it will work.. simple fence adjustments, the miter slot in T-slotted so the guide will not jump out, I can mill up a few T-slot nuts to fit for holding fingerboards... shouldn't take to much time to make the base unit to mount it on.. have a new dremel 4000 to provide the power..
what the @#&% over
Offline tghs
« Reply #23 on: March 23, 2023, 05:26:00 PM »
got a quick start on the router base,, all made with more of the free maple,, found a plate in my scrape pile that will become the new mount plate for the base.. one hardware store stop to correct screws and bolts,, a insert will be added to strap in and stabilize the dremel motor..
what the @#&% over
« Reply #24 on: March 23, 2023, 05:49:17 PM »
Perfect!  And Slim can operate the switch and speed control for you!
Offline tghs
« Reply #25 on: March 23, 2023, 06:12:39 PM »
just remember his full name is BTTW WFO Slim!!! (I don't let him anywhere near the lathe and mill rpm knobs)
what the @#&% over
Offline tghs
« Reply #26 on: March 24, 2023, 10:31:04 PM »
made up the new mounting plate, milled the dremel holding section to give more travel (helps with the thickness of the top plate) pretty much together and ready to start cutting scale moldings and the like..
what the @#&% over
Offline tghs
« Reply #27 on: March 27, 2023, 07:55:14 PM »
the under the bench drawer box arrived today,, matches nicely, has bottom edges front and back that drop over the bench's styles. Will most likely make a foam insert for the bottom drawer so tools will have their place to nest.. found my box of concrete nails,, so a set of 1/8"th, 3/16"ths and 1/4" chisels may be in the forging (standard and swan neck)
what the @#&% over
« Reply #28 on: March 27, 2023, 08:04:14 PM »
Perfect match.
What is Slims first woodcarving  project  going to be?
Offline tghs
« Reply #29 on: March 27, 2023, 08:40:15 PM »
he'll most likely make an inspection tool or measuring stick..
what the @#&% over
