Fwiw and everything I've read but not experienced with having my own surface grinder (yet) indicates a high degree of precision leveling is required to get the very best accuracy from them. I'd suggest both those pictures were efforts at getting the grinders into that level position using screw thread adjustments. Engineering wise, I'd also suggest there's much better methods to increase the foot print and amount of proper and rigid enough support for those surface grinders. For the most part and fortunately for us, vertical type mills in the sizes we might be using are already stiff enough that a slight out of level condition will show little to no effect. Yes a perfectly level condition might allow setting some parts with a level. Imo there's still better and far more accurate methods using indicators and precision sine bars when the accuracy levels are high enough to require it.But those level requirements change immediately once you get to something like a long and fairly narrow lathe bed. Yes the manufacturer's normally add cross ribbing between the lathe's longitudinal ways in an effort to stiffen the bed as much as possible. Most of that stiffening has been added so the lathe bed resists the cutting forces better and the ways remain parallel to each other. Those lathe beds are still quite flexible just because of there length to width ratio. Because of that, it really takes little force to twist the beds enough to matter. Simply bolting any bench top or on it's own normally light weight sheet metal cabinet mounted lathe down to either simply isn't anywhere close to being good enough. Wooden constructed benches also suffer with impossible to fully solve dimensional changes just due to temperature and humidity variations. There really is no available paint or sealant that can prevent those from happening on a 100% guaranteed basis. In general, posts about "lathe leveling" only go so far. That supposedly exact level is still only a static condition. It doesn't factor in the multiple points within a lathe that have variable amounts of different force vectors exerted throughout the whole machine whenever the dynamic cutting loads are introduced. Once the lathes accuracy expectations get high enough, everyone of those deflections do become important. I'd suggest that below .001"/.0254 mm accuracy, machine tool parts really do start to act somewhat like there made of rubber. And for less than any 1 ton lathe I've ever leveled, they always required further but miniscule tweaks on the screw adjustments to get them to actually turn, bore and drill truly parallel to the head stock. And for the most part, even multi ton lathes, bed mills, HBM's etc almost always come from the manufacturer with designed for the purpose screw adjustments to both fully support and level them no matter how large and heavy they are. uuu's mention of the Myford lathe example is a good one. Myford themselves sold what were called raising blocks that were also screw adjustable and in my opinion far superior to the very old recommendations I've seen mentioned in my old Model Engineer magazines about using tapered wooden shingles as a method of leveling the lathe bed. I can't think of a more frustrating method of adjustment that will also change as soon as the temperatures and humidity does. But for bench or cabinet mounted lathes, buying one is only one part of what needs to be considered as a system that needs to work together. Jo's use of that 25mm steel plate is one I've used myself and combined with some method of using adjustment screws for my lathes, does work really well. What anyone chooses to do with anything I've mentioned would of course depend on what the end user considers as being good enough for the work there doing. Greg
