Author Topic: Discussions on Kozo’s A3 Pennsy Switcher  (Read 2098 times)
« on: February 13, 2023, 05:09:09 AM »
The purpose of this thread is to provide a central repository to collect discussions of issues or difficulties with specific drawings or sections from Kozo Hiraoka's book "The A3 Pennsylvania Switcher."
Index:
Chapter 23
Figure 23-1   - Figure 23-1 vs Figure 23-11: Smokebox Mounting Stud dimension discrepancy
Figure 23-11 - Figure 23-1 vs Figure 23-11: Smokebox Mounting Stud dimension discrepancy
Chapter 28
Figure 28-8, Hole for link in the Trunnion is shown the incorrect size
Figure 28-12: Fork width in Link has the wrong dimension
Chapter 32
Figure 32-7, the height of the cab doors is shown the incorrect size
Chapter 33
Figure 33-10, Part 11, shows the wrong size hole for soldering to the axle pump water pipe
Background Info:
A few days ago on another thread, Bob, me, and a few others were sharing some difficulties we have experienced interpreting some of Kozo's drawings.  Don't get me wrong here!  Kozo Hiraoka has done a masterful job with all of his books. The drawings are excellent and there are very few errors in them.  But, there are a few. And it can take a while to really determine if it's a mistake or if you're misinterpreting something.  So, after an off-thread exchange between Bob and I, we decided it could be helpful to others to collect these discussions in one central place - outside of any one specific build.
To make this easier to navigate, the plan is to maintain an index here in this first post, by page/drawing to allow people to see what drawings have been discussed already and jump to that section.  I will be maintaining the index as best I can, but feel free to point out if I've left something out.
At least, that's the plan.
I would ask that everyone feel free to contribute to this thread for its stated purpose: to discuss issues or difficulties with specific drawings or sections from Kozo's book "The Pennsylvania A3 Switcher," but to keep it focused on that and not drift off into people's specific builds.  That should be covered in their build threads.
Hopefully, this will be a valuable resource for other people building this excellent model!
Thanks,
« Last Edit: July 12, 2024, 11:29:47 PM by Kim »
Re: Discussions on Kozo’s A3 Pennsy Switcher
« Reply #1 on: February 13, 2023, 05:15:22 AM »
To kick this off, I'll add one of the issues I found in the Boiler section (chapter 23).
In figure 23-1 (upper side view of the boiler) it shows the mounting boss on the smokebox studs to be 1/4" dia.
But in figure 23-11 he shows to ream the hole for the smoke box stud to 7/32".
I'm sure either dimension would work, but you need to make sure they are the same.  I went with 7/32" because I'd already drilled and reamed the holes in the front tube sheet, but 1/4" would work fine too.
Offline internal_fire
  • Punta Gorda, FL
« Reply #2 on: February 13, 2023, 02:14:45 PM »
There is an extensive discussion of various errors on another bulletin board.
https://livesteam.proboards.com/thread/164/mistakes-errata-changes
I  believe the board is mostly or completely inactive, but it is still accessible.
Gene
« Reply #3 on: October 31, 2023, 10:24:38 PM »
On page 168, Figure 28-12, the drawing of the Link, shows the narrower fork to be 0.785” wide.  For one thing, the part is only 1/4" wide to begin with.  But it’s clear this was supposed to be 0.0785” for the narrow fork since it is supposed to slide over the tab on the trunnion, which Kozo made 5/64” (.0781”) thick.  He probably meant 0.0785" for the fork width.
« Reply #4 on: October 31, 2023, 10:26:59 PM »
Page 168, Figure 28-8, the drawing of the Trunnion shows the hole on the larger tab to be 5/64”, which is 0.0781”.  But that hole will be receiving a #2-56 screw, and the major diameter of a #2 screw is 0.086”.  No way that’ll fit through the 5/64” hole.  Anyway, Kozo probably intended to show #44 (0.086”) for that hole which is what he uses for a #2 close fit thru hole.
« Reply #5 on: April 20, 2024, 11:29:12 PM »
On page 187, Figure 32-7 of the Cab Front, the height of the door is given as 3 7/16” (circled in red).  However, if you compare that distance with the dimensions shown on the opposite side that define the location of the 3/16" tall notch that it lines up with, the bottom of the door would be 1/8" higher that is shown here.  Checking all the other drawings and photos showing the front of the cab with the door, it’s clear that it’s supposed to be where he has it drawn and the height is off by 1/8".  I believe the height of the door should be 3 9/16” rather than what is shown in the drawing.
« Reply #6 on: July 12, 2024, 11:28:31 PM »
On page 193, Figure 33-10, part #11, the size shown for the hole for soldering the axle pump water pipe is incorrect.  It shows 5/32", just like part #10.  But the correct size for part #11 should be 3/16", as shown here in red.
This can be seen by looking at drawing 33-11 on page 189.  This drawing clearly shows that the size of the copper tube going into part #11 is 3/16" OD. The tube in question is highlighted in orange in the picture.  The bracket for that tube has a 3/16" hole (part #12), as does the T-Joint (part #9) on that tube.  It seems pretty clear that all other parts are for the 3/16" OD tube, as specified, so the receiving hole in part #11 should be 3/16" to receive that same tube. (This image only shows the lower half of drawing 33-11).
