For me its a bit like knitting: I started learning to knit by hand. In my late teens I brought a knitting machine. Yes there was the "programming" but having made possibly 20 or so jumpers on the machine I just found it boring. Knocking out jumpers did nothing for me. Years later all I do is hand knitting and I threw the knitting machine in the skip. The challenge for me is the hand skill, I also by commercial knitted jumpers from the shops - It is cheaper to buy a commercial jumper than to buy wool to knit one. Jo
Mmmmm!! Jo in her late teens
For me its a bit like knitting: I started learning to knit by hand. In my late teens I brought a knitting machine. Yes there was the "programming" but having made possibly 20 or so jumpers on the machine I just found it boring. Knocking out jumpers did nothing for me. Years later all I do is hand knitting and I threw the knitting machine in the skip. The challenge for me is the hand skill, I also by commercial knitted jumpers from the shops - It is cheaper to buy a commercial jumper than to buy wool to knit one. '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''CNC embroidery machine I don't think I could justify one of those (yet).Jo
Actually I think having a CNC mill is very beneficial, if, you can afford one that will do what you need, if, you are familiar with a solid modeling program to make parts, if, you are somewhat tech literate to understand the functionality of the machine itself and it's connection with the computer, if, you can afford all the tooling (end mill holders, collets, cutters etc.) You think making fixtures to hold parts for manual machining is a pain well a CNC mill will only cut a part in the Z direction (I know it moves in X and Y also) just like manual machining so if the part has details on the sides or bottom then you have to use a fixture or tooling setup to do those sides. It's not just pop the part into the machine and wait for the finished product to come out. Some CNC mills don't have automatic tool changers so at the end of a cutting cycle the operator has to manually change the tools.
One issue is having access to a decent CAD / CAM program. That is where there's lots of time savings to be had as an amateur that doesn't use it frequently. I'm sure that if I used it more I'd learn more tricks to be faster in programming but for now I'm pretty slow. Also, not to turn this thread into a what software to use discussion but I'm leaning towards buying Alibre Workshop bundle (Alibre Atom and MeshCam) at the moment as a way of escaping from Fusion360 ever dwindling free offering. It looks like the 3-axis CAM (Meshcam) is really easy – so hopefully that makes it easier to get off the PC and hop into the shop to make stuff.
Quote from: Jo on January 31, 2023, 04:20:01 PMCNC embroidery machine I don't think I could justify one of those (yet).Strange Jo only a couple of days ago you seemed interested in CNC embroidery yet now you don't seen to want to let a machine do some of the work
Actually I think having a CNC mill is very beneficial, if, you can afford one that will do what you need, if, you are familiar with a solid modeling program to make parts, if, you are somewhat tech literate to understand the functionality of the machine itself and it's connection with the computer, if, you can afford all the tooling (end mill holders, collets, cutters etc.) You think making fixtures to hold parts for manual machining is a pain well a CNC mill will only cut a part in the Z direction (I know it moves in X and Y also) just like manual machining so if the part has details on the sides or bottom then you have to use a fixture or tooling setup to do those sides. It's not just pop the part into the machine and wait for the finished product to come out. Some CNC mills don't have automatic tool changers so at the end of a cutting cycle the operator has to manually change the tools. Now don't take the preceding paragraph as me being against having or using a CNC mill. On the contrary! I would love to have one but do I really need one? No. To make one of two engines or models per year certainly doesn't justify having a CNC mill. Lord knows I spend enough time on the computer making 3d models for my 3d printer and 2d drawings for everything I make. Most of the long time members on the forum know me and my work. The one model I made (T-5 transmission) took hours and hours of manual machining and hand work to complete the housings alone. I would have relished having a CNC mill to do the work but after the parts were made how long would it have been before it was put to use again. I do a lot more machining on my manual lathe and mill in the course of day than I would on a CNC machine.
