Author Topic: INFINITY CUBE in WOOD  (Read 3856 times)
Offline Robert Hornby
  • Terrigal NSW Australia
Re: INFINITY CUBE in WOOD
« Reply #15 on: January 30, 2023, 06:07:01 AM »
I surely don't understand all the "emphases" on using mitered corners. Especially on wood ones.  Is it just to avoid seeing any endgrain??
   ...lew...  (an engineer without any "artistic" thought)
Just like with aa wooden picture frame, using miter joints gives a uniform appearance with the grain looking like it is continuing around the corner, looks more like one continuous piece. When gluing, it also gives a stronger joint, more of a hybrid end grain/side grain surface.
Yes the mitered joints just give a more pleasant appearance, and there is a greater surface for the glue.
Hi , On the isometric drawing it would be interesting to see all the hidden lines on the back faces of the square timbers , shown dotted to see where they actually go/end up ??
Willy
I did consider showing hidden lines but it got too messy.
No, I won't be dowling the joints, they will not need it.
Robert, are you going to dowel the joints?
Offline Lew Hartswick
  • Albuquerque, New Mexico, USA
« Reply #16 on: January 30, 2023, 01:37:51 PM »
:-)   Well Rosettes and Plinth blocks use to do great job before mitered joints on window and door trim. I know all about those from doing some work on a house in VA for a few years. :-)
   ...lew...
« Reply #17 on: February 02, 2023, 09:31:50 PM »
Actual progress has commenced with the cutting and mitering of some of the pieces. I am using a home made mitre block which I have dialed in to be sure the cuts are precisely 45 deg. I made a test join with a couple of scrap pieces to see how the join came out and I am happy with it. I tried to pull them apart with my hands but failed and had to give quite a hard knock with a hammer, so the joins will be strong.
« Reply #18 on: February 02, 2023, 10:20:59 PM »
That's looking good, Robert!  You'll have it done in no time  :popcorn:
« Reply #19 on: February 02, 2023, 11:24:33 PM »
Looks like you managed to get some extremely clean 45 degree cuts on the mill  :praise2:
Per      :cheers:
« Reply #20 on: April 20, 2023, 01:26:40 AM »
I have been distracted lately with other stuff around the house and not been able to spend much time in the workshop. However I have managed to cut some more wood for the cube. It is a bit tricky making sure the bits are glued together at 90 deg.
« Reply #21 on: April 20, 2023, 04:04:54 PM »
Due to a lack of display space in my den of antiquity, I elected to make a miniature version.  To assure 90 degree angles, I cut some slices from a piece of aluminum angle and flattened the edge to allow room for glue squeeze out.  Each joint was clamped as shown in the photo.  I've used this trick in past projects and it's always served me well.
Making a miniature like this  is fiddly at best.  My usual wood glue took too long to dry so I used super glue.
« Reply #22 on: April 20, 2023, 06:25:35 PM »
That's very nice Marv! And quite small!  Shouldn't have any problem stowing that somewhere in the Den of Antiquity  :Lol:
« Reply #23 on: April 21, 2023, 11:53:23 PM »
Thanks for the idea Marv, of the mini square to assist with the clamping to acheive the 90 deg. I just used my square, but your method would be much better.
« Reply #24 on: April 25, 2023, 01:57:01 AM »
Finally finished the cube. It really it is only an exercise in cutting the wood to exact lengths and getting the 45 deg angles right.
« Reply #25 on: April 25, 2023, 05:13:10 AM »
Wow!  That looks great!  Well done, Robert!   :ThumbsUp: :popcorn:
As you said, it's really just an exercise in expertise and precision, nothing more.  But then, doesn't that describe almost everything we do?  :Lol:
Offline springcrocus
    • Steve's Britannia
« Reply #26 on: April 25, 2023, 07:21:04 AM »
Looks very impressive! Nice work. :ThumbsUp: :ThumbsUp: :cheers:
 Regards, Steve
Member of a local model engineers society
www.stevesbritannia.co.uk
« Reply #27 on: April 25, 2023, 03:09:10 PM »
Here's your next project...
This is a miniature tensegrity table. 'Tensegrity' is a Buckminster Fuller portmanteau of 'tensional' and 'integrity' and refers to structures where the flexible members are under tension and the rigid members are under compression. You can read more about it in Wikipedia...
https://en.wikipedia.org/wiki/Tensegrity
<a href="https://www.youtube.com/watch?v=Qwp4OrFCpTo" target="_blank">http://www.youtube.com/watch?v=Qwp4OrFCpTo</a>
« Reply #28 on: April 25, 2023, 07:29:46 PM »
Thank you for showing that Marv ...!
I have never heard of the concept before - so there are some rather unique examples in your link + in your case, I kind of think that you might know them from the Math too ....
« Reply #29 on: April 26, 2023, 04:24:42 AM »
Thanks for that Marv, I will certainly give it a go.
