Author Topic: INFINITY CUBE in WOOD  (Read 3845 times)
Offline Robert Hornby
  • Terrigal NSW Australia
« on: January 28, 2023, 06:01:30 AM »
I bit the bullet and have drawn up what I intend to make and will use some timber that I have lying about. It an Australian hardwood, SPOTTED GUM, mainly used for polished floor boarding but it does machine and polish up very nicely. (I have made some gear stick knobs for Jaguars out of it - but that is another story).
I will machine the pieces to 18mm x 18mm square in the 3 different lengths. Getting the 45 deg angles will need to be done very carefully as I would like the joints to be free of any gaps.
The overall size of the cube will be 130mm x 130mm x 130mm.  I have attached the drawings via a PDF file so unsure if that will publish. If not I will scan and attach.
Re: INFINITY CUBE in WOOD
« Reply #1 on: January 28, 2023, 06:12:41 AM »
I have scanned my drawings and attached to see if that is better.
Offline springcrocus
    • Steve's Britannia
« Reply #2 on: January 28, 2023, 08:09:33 AM »
That seems fun. Look forward to seeing this built "in the flesh" so to speak.  :popcorn:
I believe that some on here consider certain brown-coloured materials to be taboo.  :Lol: :Lol:
Regards, Steve
Member of a local model engineers society
www.stevesbritannia.co.uk
Offline Alston
« Reply #3 on: January 28, 2023, 10:45:26 AM »
I’ve also done some quick calculations and will be making something similar milled in Aluminium and bolted together with three socket screws. Too cold to work in the shed though and I have other jobs so it could take a while. I look forward to seeing how yours pans out. What adhesive will you be using? I like Urea Formaldehyde for stuff like this.
« Reply #4 on: January 28, 2023, 11:54:11 AM »
I will use Aquadhere, it is just a water-based wood glue. I have used it on many wood joining jobs with 100% success as long as the mating surfaces are clean and true. I use it on my gear stick knobs, they are made from 3 pieces of Spotted Gum.
« Reply #5 on: January 28, 2023, 04:14:41 PM »
That's a sharp looking shift Knob, Robert!
Looking forward to seeing your Infinity Cube too!
« Reply #6 on: January 28, 2023, 04:44:10 PM »
Looks to be a fun project  :ThumbsUp:  :ThumbsUp: Another wood I have never heard of  :headscratch:
« Reply #7 on: January 28, 2023, 06:00:35 PM »
In your first diagram you show shapes C,J,M,R (94 mm long) and F,P (58 mm long) as angled on one end but seemingly square on the other end.  When I look at the second diagram it appears they are angled on both ends, but these angles are cut on orthogonal faces.
Is this correct?
« Reply #8 on: January 28, 2023, 09:10:27 PM »
Is this correct?
Quite correct, I missed a line of 'F" and "P" and also 'C' 'J' 'M' 'R' on the cutting list
The angled cuts are on different faces.
« Reply #9 on: January 28, 2023, 09:41:05 PM »
Revision 1 for the cutting list. I have drawn the shape to better show the cut on different faces.
« Reply #10 on: January 28, 2023, 11:37:45 PM »
Hi , On the isometric drawing it would be interesting to see all the hidden lines on the back faces of the square timbers , shown dotted to see where they actually go/end up ??
Willy
Offline Alston
« Reply #11 on: January 29, 2023, 11:17:45 AM »
I’ve had creep on several projects using PVA. This becomes particularly noticeable on subsequently turned items. As a result I no longer use PVA for important jobs where creep could end up spoiling it. Probably not an issue in your case though gluing end grain.
Offline Lew Hartswick
  • Albuquerque, New Mexico, USA
« Reply #12 on: January 29, 2023, 01:48:05 PM »
I surely don't understand all the "emphases" on using mitered corners. Especially on wood ones.  Is it just to avoid seeing any endgrain??
   ...lew...  (an engineer without any "artistic" thought)
« Reply #13 on: January 29, 2023, 01:53:07 PM »
Just like with aa wooden picture frame, using miter joints gives a uniform appearance with the grain looking like it is continuing around the corner, looks more like one continuous piece. When gluing, it also gives a stronger joint, more of a hybrid end grain/side grain surface.
Offline vtsteam
« Reply #14 on: January 29, 2023, 03:55:43 PM »
Robert, are you going to dowel the joints?
