Author Topic: Farm Boy  (Read 47106 times)
Re: Farm Boy
« Reply #135 on: July 11, 2025, 07:45:23 PM »
Beautiful result so far  :ThumbsUp:
Per    :cheers:
Offline Dalboy
Re: Farm Boy
« Reply #136 on: July 12, 2025, 07:01:37 PM »
Thank you.
Main engine assembled and timing and valve clearance set, need to find a spring for the governor balls. Will search through my spring box. As it is, I found a spring for another part and ping it went off on it’s travels never to return, luckily I found another to replace it with.
Working on a Fuel ordered while waiting for that I can work on the wiring and getting the fuel tank fitted, and a top made as well as an exhaust that will look the part all set up ready to machine that.
Offline Dalboy
Re: Farm Boy
« Reply #137 on: September 27, 2025, 12:24:12 PM »
I seem to be a little behind on posting progress.
I have been working on a lot of small bits and pieces, as well as a small side project.
First the side project which is complete, I needed some clamps so made these two.
Then the ignition wiring except for an on/off switch which has arrived this morning
Offline Dalboy
Re: Farm Boy
« Reply #138 on: October 04, 2025, 12:06:29 PM »
All the machine work completed, the only thing left is to run it when the fuel pipe arrives.
I managed to find a display case and now it has a home, the wife thought it would be better so it does not collect dust.
The display case comes flat packed along with some cotton gloves to assemble it as well as a cloth for cleaning it with when needed. There is also a string of coloured LED lights but I have not put these in.
Offline samc88
Re: Farm Boy
« Reply #139 on: October 04, 2025, 10:20:12 PM »
Lovely looking engine, who made the display case? It might come in useful to members of the model club I am in l.
Looking forward to seeing the finished article running!
Offline Dalboy
Re: Farm Boy
« Reply #140 on: October 05, 2025, 07:40:15 AM »
Thank you.
The display case I got from Amazon just look for "Display Case"
Sorry not sure how to put a direct link
Re: Farm Boy
« Reply #141 on: October 05, 2025, 12:09:34 PM »
Excellent  :praise2: Not long to the first pops  :)
