You didn't happen to pick up any of Chris's shop elves did you? Kim
That was a very quick build and the result looks Great They appear to be ready for first Pop Do you have Props, fuel and experience running and breaking in CI (Compression Ignition) Engines ?If not - you should do a bit of reading on Adrians Great page :https://adriansmodelaeroengines.com/See about Fuel, Break in :https://adriansmodelaeroengines.com/catalog/main.php?cat_id=3Hope to see a Video of them running Per
Wow, miss a few days and Andrew bangs out a nearly complete engine!Agree with others, the grit blast finish makes a lovely contrast with the machinined areas.
