Finally I could do the surfacing with a smaller 4 flute end mill, which would eliminate the thunk thunk thunk of the massive fly cutter.
I'm not anxious to use grease between the table and the base. I'm thinking that might be a swarf and dirt trap.
Thanks Dave and Ron! I still use it, though my main lathe now is the second I've built, a 9" by 12" of my own design, which takes up the same bench space, but is much much heavier, and has split ways. The 9"x 12" borrows a lot of design elements and component dimensions from the 12" x 36" Craftsman I also own, but also some constructional features I liked about the Gingery. I thought about it as similar to shortening the 12" x 36" down to a heavy mini bench lathe length, but retaining the original rigidity. The main reason for doing that was to have something that fit in the tiny workshop shed near the house.
