I could send you the design files for the Ohio triple expansion/four cylinder battleship engine for you to cast and build... I'd need a set back for quality control...
Quote from: crueby on December 31, 2022, 05:29:46 PMI could send you the design files for the Ohio triple expansion/four cylinder battleship engine for you to cast and build... I'd need a set back for quality control... Not exactly IC though is it Chris? However you’ve got me on the triple expansion with four cylinders…. Graham.
Makes you wonder what they were thinking? Lower center of gravity maybe?
How about a Crossley Type H or J? As you know, I started to make a pattern for the body several years ago but it became a paperweight and I never got any further with it. Always an engine that I admired at rallies.As an alternative, how about a four cylinder flame ignition Gardner(?) like the one at the Anson museum?
Wow, then forget about my "uneven firing". They do every stroke.
