Author Topic: stationary boiler  (Read 25787 times)
Re: stationary boiler
« Reply #15 on: December 26, 2022, 05:17:59 PM »
Hello, everyone,
Today I tested the boiler. The gas regulator works great. After 6 minutes a pressure of 1 bar was present. At a pressure of 3 bar, the burner goes to a small flame.
The feed pump also works. I think I'll put another gauge on the heater side.
And next, a steam engine will be connected.
« Reply #16 on: December 26, 2022, 05:21:11 PM »
Video:
<a href="https://www.youtube.com/watch?v=nBJfEdrfWE4" target="_blank">http://www.youtube.com/watch?v=nBJfEdrfWE4</a>
« Reply #17 on: December 26, 2022, 05:27:14 PM »
Great video, burner and boiler system is very impressive! Going to be great to see the engine running from it.
« Reply #18 on: December 26, 2022, 05:58:44 PM »
It still Christmas - so you made it in time  ;)   :whoohoo:
Looks like all is working to Specifications  :ThumbsUp:
« Reply #19 on: December 26, 2022, 06:09:16 PM »
Thank you Chris!
Was the weather, the cold, bearable at your home? Or did it not get as cold as the news shows me.
« Reply #20 on: December 26, 2022, 06:14:27 PM »
yes Per the first stage is done. I used a lot of parts here that come from the collection box. I mainly had to redo pipes and fittings.
Now two pipes for the machine. Could I do it this year?
Greetings Michael
« Reply #21 on: December 26, 2022, 06:55:10 PM »
Thank you Chris!
We got down to about 5 degrees farenheit with 40 to 50 mph wind gusts, but not much snow where I am. Its back up closer to the freezing point now, supposed to be above freezing in a couple days. Power flixkered a number of times but never went out.
« Reply #22 on: December 30, 2022, 05:34:30 PM »
Today I heated up the boiler again.
This time with the steam engine.
<a href="https://www.youtube.com/watch?v=ExJeRCMMGeo" target="_blank">http://www.youtube.com/watch?v=ExJeRCMMGeo</a>
« Reply #23 on: December 30, 2022, 05:47:25 PM »
What a beautiful setup!  Running great, looks ready for the museum!   :ThumbsUp: :ThumbsUp:
« Reply #24 on: December 30, 2022, 06:36:00 PM »
thanks, finally a steam engine plate that I can wear alone. I am getting older.
« Reply #25 on: December 30, 2022, 07:44:08 PM »
Congratulations Michael!  That's a wonderful boiler and engine setup you got running there.  Very nice!
Offline Mcgyver
  • Toronto
« Reply #26 on: December 30, 2022, 08:24:56 PM »
Beautiful work, that really sets the bar for visual appearance....nothing like lots of brass and wood to take the prize!
Can you give some details on the brass straps?  How did you make what looks like a profiled one on the front?  Are the straps tightened underneath?
« Last Edit: December 30, 2022, 08:46:09 PM by Mcgyver »
  • Oregon
« Reply #27 on: December 30, 2022, 08:38:35 PM »
I like everything about that. Both the boiler set-up and the engine are beautiful in form and function! :ThumbsUp: :ThumbsUp:
« Reply #28 on: December 30, 2022, 09:07:15 PM »
thanks guys for the kind words.
The end ring is a curved tube that is soldered to a brass band with silver solder. That makes a nice ending.
Greetings Michael
Offline vtsteam
« Reply #29 on: December 31, 2022, 03:18:27 AM »
Really nice!  :NotWorthy: :NotWorthy: :NotWorthy: :cheers:
